200+ woodworking book reviews
Varnish over latex paint
Norm Knoxville
Does anyone have any experience applying oil based varnish over latex paint. I have an outdoor table painted the perfect color but the lady wants a varnish finish. I have some satin spar on hand that produces the finish she likes, but I hesitate to apply it until I hear from someone that has experience. Thank you.
Re: Varnish over latex paint
Lee Grindinger
Won't fly
Lee Grindinger
The film varnish creates moves quite differently compared to a latex film, this will destroy the bond between the two sooner rather than later. I'd suggest you take a sample to a decent paint store and have the needed quantity made up as an oil based enamel paint, sand most of the latex off and coat the piece with enamel. Choose the gloss your wife wants and refinish the piece.
Lee
Clint Searl
Clint Searl
I've done oil based poly, water based poly, and solvent lacquer over Latex/acrylic with no problem, going back to the mid-70's. All interior, however, but I wouldn't expect a problem with exterior.
Clint
I agree
Bill Tindall
Outside you will be using a spar varnish which is especially flexible.
Re: I agree
Norm Knoxville
Thank you for the advise. We'll give the satin spar a shot.
why the overcoat?
Bill Tindall
Upon further thinking about this question I began to wonder why someone would want to varnish over paint. To a first approximation oil paint is just varnish with pigment in it. Could there be a better route to what ever they want to achieve.
There are some significant disadvantages to be considered. The varnish will be less durable than exterior paint and the varnish will yellow in the sun and change the paint hue.
Re: why the overcoat?
Bill Howatt
I tried the varnish over paint idea on some kitchen cupboard doors. It changed the color and didn't look good at all but my colors weren't likely the same as the OP's.
I also have to wonder about the durability of the varnish over paint in the sun. As is the case with so many finishing problems, a lot has to do with how compatible the products are and the surface preparation for each layer of the finish. This is often the reason for mixed messages for finishing questions where some say it works and others say it doesn't.
Bill
Norm Knoxville
The table is a repair job for my wife's friend. It is mixed woods, PT pine and cypress. It was originally put together by a finish carpenter working at her home. He put it together with construction adhesive and pin nails and over time it failed and fell apart. There is sentimental value for the piece so I just took it apart, machined, made new mouldings, sanded etc and assembled it properly. Originally there was a semi transparent stain I think, she doesn't remember and the deck is not a match.
I picked an exterior paint because I thought it would hold up well outdoors and picked flat to mask imperfections in the old wood and avoid glare. The satin varnish was my idea because she had complimented the sheen on a small table I made for my wife. Maybe best bet is just to stay with the paint as is and see how she likes it over time. I'll hold the spar in reserve for another project.
Thank you for your thoughts and advice.
Clear Acrylic Latex paint is what you need
Bill Hammond, Oregon Coast
Exterior dark tinting base usually is clear. Looks milky in the can but like poly it dries clear and has UV protection and is intended for exterior use. It also goes over regular latex paint just fine and tends to not yellow like poly or varnish does.
HTH
Bill
FredD
Well your right Norm , exterior paint does hold up rather well , a lot better then other film, finishes and the best part is, it is easy to touch up or recoat with no compatibility issues. Plus all of the various glosses are available in paint.
FredD
