We value your privacy.
I have a question about how to attach a screen onto a wooden screen door.
This is mahogany, and precious to me. Finding straight mahogany here took some real digging. I had to make it very light. It's a fairly light frame of simple design.
The first one I built, used fiberglass screen snd it's been fine for over 10 years now, having just stapled it on with heavy staples and covered with some moulding i made and then screwed the strips on.
The one I have yet to complete is a gift for family and I offered the option of screen cloth. They chose copper or brass screen.
Does anyone have ideas how best to attach it? Should I just use the same method?
when I lived in California I made Oak screen doors 7/8ths thick and made step moulding for each side that formed that left a 5/16ths gap between the the moulding which was filled with a standard 5/16ths by 1/2 inch Bronze anodized aluminum frame which held the screen , this was made for me by a Glazier 25 frames at a time all the same size .
I used spring loaded hinges which mounted on the stile front and mortised into the door jamb.
These are made for screen doors by National Hardware.
Then using a simple centering jig I edged bored the door and and a though hole in the stile connecting the edge bore and installed Brass Dexter screen door hinges which have a handle fron and back with a lever .
Looking at the bottom of your door dividers you may not have enough stile width for step moulding , but it's a thought.
...on a few things. If this is going to be strictly a screen door -- i.e., not a storm door in winter, with interchangeable glass/plexi sash(es) -- you might want to do something as simple as stretching the screen across the entire door opening and securing it with battens screwed to the face, around the perimeter and across the center rail. The challenges there are to stretch the screen tightly and evenly and to secure it well. You could rout a narrow groove on the face of the door and roll the screen edges into it with vinyl screen molding.
For removable sashes, the traditional method was to make separate frames for the screen and storm window, with overall dimensions 3/4" larger than the opening. Rout 3/8" wide rabbets on the *inside* face of the sides, and on the *outside* face of the bottom rail, and complementary rabbets on the frame. This was to insure that water drained *out* at the bottom of the sash. The top part of the frame was held firmly in the opening by two spring-loaded pins set in the sash stiles. This arrangement won't work with your lower picket arrangement, so I don't know what to tell you to do there, except possibly put a piece of plexiglas across the bottom section.
If you don't want to make a wooden sash, you can do the same rabbet arrangement and use a typical aluminum-framed sash. Hold it in place with screwed battens at the top and sides.
The staple-and-molding method is the classic method, around here at least (California North Coast). One of its advantages is that you can stretch the screen to reduce wrinkling. Lay the screen door flat on a large surface (I use our picnic table). Put thin boards* under the top and bottom of the screen, and a 1x4 or so on top of the door at the middle. The boards should be very smooth, maybe even padded with paper, where they touch the door. The board in the middle should be very smooth on top, and you might want to round off its upper corners. Clamp the middle board down, so that the door is curved over its length. Staple the screen top and bottom, then remove the board in the middle by unclamping and sliding it out (this is why the smoothness). Your screen should now be taut over its length. Finish stapling the sides and apply your molding.
*For the fiberglass screen I use, 1x2s are about right. I've never done this with metal screen, which is stiffer and may be less prone to wrinkling. You might want to try a couple of scraps of 1/2" plywood, although the method works best when all three boards are the same thickness. If you've got a big enough surface to do this on, you might be able to leave out the middle board by clamping each side of the screen door to the surface; this would be better than the middle board, because you would avoid the risk of snagging your screen while removing the board.
if you can find the brass or bronze screen, you'll find it a lot easier to install flat and wrinkle free than either fiber glass or aluminum. This is one I replaced a few years ago. it's just stapled to the frame with the flat moldings tacked on with brads. don't go crazy with the staples. Th screen is rigid enough that a few staples along with the tacks and molding will hold it fine.
I greatly appreciate all of the ideas from experience of you gents. It's just what I had hoped for.
Being that the frame is light and is rather a large doorway, I believe will simply staple and batten with brass screws and feel that not so cheesy as I had been thinking... and spare some staples.
Will try a weight at end of screen to tension before fastening, if not enough then a slight bow as suggested.
The nature of this wood is so wonderful that I don't want any aspect to lessen the beauty of it. This, as the last will finish with Ace Hardware Tung Oil. Nature and use has aged the first one, has gained by it.
the third one is glued up and may add some hardware to allow winter glass since it is smaller.
Your door looks light and elegant. It appears you have used M & T joints. But, I suspect you need a diagonal brace to keep it from sagging. Just to be safe.
