200+ woodworking book reviews
Bed Question
Bed Question
Bed Question
I thinking I am going to make a bed. Queen Size
Anybody know the size of the box springs? Actual size so I know how big to make the frame.
Re: Bed Question
Roughly same as mattress size
It is advised to make the dimensions just a little bit larger (1" or so) as many of the box springs have corner protectors. If you don't "upsize" your dimensions, the box springs will not fit (DAMHIKT) and will scrape the bed frame. Another thought - get a "split" queen size box spring. They fit through doors and around corners a lot better.
Re: Bed Question
Yeah But, Can you put some numbers on that?
Re: Bed Question
Re: Yeah But, Can you put some numbers on that?
Carol Reed
Take your tape measure to the mattress store.
Tell the guy you have this homemade bed frame and you want to know if his mattresses will fit, or if you have to continue sleeping on the floor. Talk fast. They usually go away muttering and let you to your own devices. DAMHIKT!
Re: Bed Question
A queen is 60" x 80"
Neal in San Jose
But you might want to measure yours just to make sure.
Re: Bed Question
Re: Bed Question
Jesse Cloud
I know this sounds awkward, but next time I do this, I will either buy the mattress first or at least pick one out and measure it at the store.
The problem is that the width and length may be pretty standard, but the thickness varies hugely.
Last time I made a bed, I used the old mattress for dimensions, but the wife fell for a very thick one at the store. We practically needed a footstool to climb into bed.
Re: Bed Question
Thanks Everybody and....
I am going to make one for my guest room that will be a Queen size. My son wants one that is king sized. So for now 60 by 80 it is. I'll make the inside dimension of the frame 61 by 81.
The idea of buying the mattress first is a good one, but the money for this project is coming in over the next couple of months. Thought I might get a head start by building the frame and then going to buy the mattress later. Might be good to have my eye on the exact one. My cousin has a bed that turned out so tall they actually do need step stools. Come to think of it, Step stools might be a good project.
Re: Bed Question
Re: Bed Question
John Cotten
Jesse is correct, I have built a few beds over the years, I have found that not all mattresses are the same dimensions, some are a bit larger and thicknesses vary greatly. Measure the mattress you want to make the bed frame for first.
Re: Bed Question
Re: Bed Question
mdclor
Barry,
It also depends if the mattress will sit inside the frame or above it on box springs. My LOML Jr bought a foam mattress for LOML III that is used without a box spring. About half the mattress will be inside the frame, so I made the frame 3 inches wider and longer than the mattress to allow hand room for tucking in fitted sheets.
I completely agree that you should have the exact dimensions (h, w & d) of the mattress before designing the frame. The one I made will have the mattress top 18" off the floor and that seems about right for a 4 year old. If she wants it higher later, we can always add a box spring.
HTH,
Merle
Re: Bed Question
Re: Thanks Everybody and....
Bruce, a MN Galoot
I've made a half dozen or so, and make them so they sit on top of a platform, not inside an external frame. One dimension that is critical for me is to make the height of the bed so that I can sit on it comfortably with my feet on the floor, not dangling in space. You don't need a box spring. One of my mattresses is 20 years old and still works fine.
Re: Bed Question
Re: Bed Question *LINK*
David Hay Denver
A couple of comments:
1. I've attached a link with more information than you probably cared to know about bed sizing. (I found the names of bed sizes in other countries fun to learn about)
2. While the idea of measuring the actual mattress/box spring intended to be used is good advice, I'd design the bed to allow some tolerance in mattress sizes. At some point, the mattress and box springs will need to be replaced, so allow for a little variance in mattress sizes.
David
Bed Sizes
