Tip to remember-do milling and joinery quickly
Stephen Kirk
I'm building a rolling kitchen island which has become a several month project that is worked on when I get time. Now, even though I flattened, acclimated and then finished sized my pieces at the start, things still like to move around. I definitely see the fit of joints that were cut weeks ago changing. I'm using sly mortise and tenon joints. If a rail or leg develops even a bit of twist it'll throw things off. I think I can work with it all and bring things into square.
So, as something I'm learning, try to move throw whole chunks of work as quickly as you can. For me, this means I should have done the legs, rails, stretchers within a few days, not a few weeks. Sometimes life happens and then you get to deal with a project going a bit off. And yeah, I'm using sly solid wood, plywood resists this tendency a bit better.
Hope maybe this can help someone!
