Refinishing kitchen cabinets
Warren White
Good morning! I am looking for advice and counsel from the experts.
I have a set of kitchen cabinets (oak) that need refinishing. My guess is that they have a clear lacquer finish over an oak stain. The finish is worn and soiled where we open the cabinets (no knobs).
I plan on removing the doors and drawer fronts for cleaning and application of lacquer. I have an HVLP sprayer.
What do you suggest for cleaning and prepping the surface? Any precautions or hints you might suggest? I have Fuhr pre-cat waterborne lacquer that I plan on using, unless you think that won't wear well enough.
I could also tent the area where the kitchen cabinets are and spray the frames, but my thought is that I could much easier pad or brush the material on.
Your comments and suggestions are most welcome.
Warren
Re: Refinishing kitchen cabinets
Okay, Warren,
Since nobody else is picking up your question . . .
Easiest cleaner will be naptha; it'll remove the finger oils, grime, and wax from years of spray cabinet cleaners or polishes without dissolving the old finish; it then evaporates quickly. When you're done with that step, you'll need to reassess your next move. If the finish shows up as sound, you might wish to stop. If not, then you you'll need some more "stuff" depending on the following:
1. If the old stain has eroded leaving a lighter patch, you'll need the abrade and then restain to get your color back to something approaching even. The other approach here is to have your door(s) vat-stripped and then start from scratch with stain.
2. If you've got even color, you should reseal the entire door with a coat of dewaxed shellac; a fresh can of SealCoat will do nicely. This will seal in any oil or extraneous silicone residue which you didn't remove in Step 1. This kind of sealer is very important if you're using a waterborne top coat, as it will not stick to silicone on the surface, and you'll have a real mess.
3. Let the shellac dry for several days to make sure all of the alcohol has evaporated, then apply your top coat per label directions.
Hope this helps.
Warren White
Thank you Mark. I appreciate your time, and your advise.
Warren
