OT - PVC sprinkler line repair
doug f, san clemente, ca
I've discovered a crack, or more likely, a shovel ding about 2" long in a sprinkler line. It's in the middle of the run and there is no "give" in the pipe to be able to insert a patch.
Somewhere in my age-addled brain I seem to remember a sleeve that can be glued around a pvc pipe to repair leaks. It was essentially a bit larger pipe that was split lengthwise and had a rudimentary hinge on one side. Am I nuts or do these actually exist?
Any suggestions?
Thanks for the help, folks.
Doug
Re: OT - PVC sprinkler line repair
Yes
your hardware store or big box store should have them. The ones at my local Ace Hardware are kind of hinged to fit around the pipe.
Re: OT - PVC sprinkler line repair *LINK*
Galen Vetterick
If this is in the middle of a run cut it in two and dig back far enough to lift the pipe and install a compression coupling. It will slide onto the pipe far enough to slip it on one side then align and slide it half over the other section and tighten the compression ends.
They make expansion joints that you can use as a coupling as well but more money.
Fernco makes the rubber hose and hose clamp couplings but I have not used underground.
They make pvc saddle fittings but they normally have a branch run then you would need to buy a plug as well.
Galen
http://www.usahardware.com/inet/shop/item/80420/icn/20-156265/genova/37107.htm
Alan in Little Washington (NC)
Cut the pipe and use a compression fitting, telescoping coupling, or the easiest and cheapest a repair coupling with no stop in the middle. With the repair coupling you slip it completely over one pipe far enough expose the last few inches of the pipe. Apply PVC adhesive (slow setting recommended) to both ends, align the pipe ends, and slide the coupling in place.
The repair coupling should be available at any big box store or plumbing supply.
Thanks, everyone.
Looks like it's back to the hardware store today.
Doug
Andy Wright - Allen, TX
I have used the compression fittings in the past in my sprinkler (underground) with no problems
