200+ woodworking book reviews
Wood Cut-offs as Floor Tiles?
Ok, so I end up with lots of hardwood cut-offs. So I was wondering if they could be used as flooring like tiles? Anyone heard of this or seen it? I have seen end grain wood floors but in this case these would be an assortment of 12X12, 12X6, and 6X6 cutoffs laid like tiles on a sub-floor. Doable?
I'm thinking a construction adhesive bed? And what about grouting with a flexible grout? Epoxy?
Or is the whole idea insane?
Any input here would be appreciated!
Tom
Re: Wood Cut-offs as Floor Tiles?
I have not done wood tiles, but I have done a bunch of slate. I knew nothing about grout and was somewhat intimidated by it, so I bought the type of slate that was cut full size. There was a Pattern, (A10, butt cut). I laid out the pieces and then spent time switching them around to improve the fit. To avoid having to number them and reinstall them in the exact same pattern, I would just lift them out and put a circle of construction adhesive under each one. (this is a plywood subfloor and I used BF Goodrich PL400 adhesive) once the were all down I would stand on them with my butt against the wall and try to slide them to the center for the room and tighten them up. After I got them as good as I could, I let the glue set and caulked/grouted any open joints with black silicone caulk. (Didn't take much). I have a foyer floor that is over thirty years old and later I did my stair treads and they must be 25 years old. I must have done twenty five foyers over the years I was building. The only company I ever got was from a guy who tried to remove his (redecorating) and he tried everything he could think of including solvent and a torch and finally tore out the plywood with the slate still attached.
Wood would introduce different parameters, such as movement with moisture change and warping. I think it would work if you could find the correct grout.
In the Old days
Ray - Middletown, IN
In the punch press departments the floors were always wood, laid end grain up. It helped to absorb the vibration produced by the presses and soaked up the oil byproduct used as lubrication. When the pieces were fully soaked they were pulled up and replaced. I see no reason why a tiled floor with cutoffs wouldn't be a good idea. I might be tempted to lay a half inch or so of sand and lay the pieces down just like a brick patio, no glue or grout. Sweep some sand to lock in place and be done with it. Would make it easy to fix any oops down the road.
Ray
Ever try to tiptoe silently over a Parquet floor?
Al Kapocius
Lee Grindinger
Forget grout, use rope
Lee Grindinger
You'll need a flexible gap filler and rope fills this bill nicely, it's still in place in many old wide board floors.
Lee
Re: Wood Cut-offs as Floor Tiles? *LINK*
John McGaw
After a turning demonstration by David Ellsworth some years back the group was talking about the floor on the woodworking shop at Indiana State University (PA) where the demo was held. It was end-grain wood. David said that he's seen this a few times and that this was a common floor for old-time industrial buildings because it resists damage and is easily repaired since they were laid with no fasteners or adhesive. The floors tended to be lightly oiled for sealing and had a "grout" which was made up of linseed oil and sawdust IIRC.
I found one company which still sells materials for such floors but there are probably more of them.
http://www.jennisonwright.com/woodblock.html
I have seen end grain floors....very durable. But my cutoffs tend to be ends of 3/4" thick boards. So rather than go end grain I wondered about flat, like tiles. Too much work to tongue and groove everything. So then that's when I wondered about adhsehive set with a flexible grout of some kind. I think it would look cool but will it work?
T.
Dick Coers
Shellac and powdered cork makes a good flexible grout. Are you talking about different species? Differences in expansion rates might be trouble. How about resawing and glueing to plywood. Your own engineered floor. You probably couldn't use 12" wide boards.
I'm Back, A different take.....
In the old days they had huge trees they cut by hand and sawed into wide boards. In Colonial Williamsburg there is a lesson that might apply. They had the wide boards, the plywood of the day. What they knew was that those boards shrank and swelled a lot, Especially in houses that had no central heat and air. In the downscale houses and upstairs in the up scale ones they used wide planks. Downstairs they used narrower planks. In the Governor's Palace they used planks that were about an inch wide. A huge amount of work for people working with hand tools.
But they knew what we know. Wood shrinks and swells. In the houses with very wide planks, they shrank so badly they came back and Installed narrow planks between them to fill the gaps. They sometimes used the rope mentioned above.
It would not be uncommon for the wood to change at least 1% in modern housing with heat and AC. Thus a ten inch wide piece could move a tenth of an inch. This is why narrow planks work better in flooring. A 2 1/4" plank might only move a couple of hundredths.
So, if you used small pieces, the movement is broken down into tiny amounts. Also, if you rotate the blocks so that the grain direction is ninety degrees to each other, the effects might be magnified.
Re: I'm Back, A different take.....
FredD
A Plank is a piece of lumber 2 to 4 inches thick and at least 8 inches wide.
FredD
Think how long it took to
plane them down to 3/4 with wooded hand planes. No wonder they invented power tools as soon as they could.
Over 14,000 pieces & no squeak.
Basil
When my buddy Tommy was building his son's house he did his son's dining room with over 14,000 little pieces of 28 different kinds of wood. The pieces were about an inch wide, three inches long and about 3/4" thick, with the ends cut on a 45 degree angle. The subfloor for the whole house was 1x6 pine screwed&glued down to the floor joist, with 3/4" plywood over a vapor barrier screwed down thru the 1x6's and into the floor joist. Then the pine flooring he made went in over all that....pretty stout flooring system. The dining room was done last. The center of the room was established and a design and pattern was established to follow. The 14,0000 pieces were glued to the 3/4" plywood with a liberal coating of TITEBOND II on all sides. It has held up well for several years without cracking or making any noise when you walk on it.
Similar work picture.
Basil
The very first picture on the page is of a large table and is similar in size of the pieces used for the dining room floor.
http://www.woodcentral.com/shots/shot139.shtml
copy and paste to get page.
