OT How to Run .exe Program?
I downladed a "hotfix" for OutLook.
It came with the following "If this hotfix was delivered with hfx.exe then it can be installed by running hfx.exe from the appropriate platform directory."
How do I do That?
Re: OT How to Run .exe Program?
Should be simple
Mike Farinella
just double click on the file name (hfx.exe)
Caution!
Jerry Nicholson
Where did you get the HotFix? If it came from Microsoft then ignore me completely but if it came from somewhere else I would suggest you proceed with extreme caution.
Jerry
Make it simpler....
What program do I use to get to the file to click on it?
I went through WORD and Displayed All Files and saw it, but when I opened it in Word I got a disclaimer.
What do I do to actually click on file?
I have Windows 7.
David Hay Denver
Can you post the URL where you downloaded the hotfix from? It might help us understand the nature of the fix and how to install it.
David
Re: Make it simpler....
Bill Howatt
Click on the ball with the Windows symbol in it (lower, left-hand corner of the screen) whch brings up the program menu.
You will notice a box with grayed letters saying:
Search programs and files
Type hfx.exe in the box and hit enter.
It will bring up a Search Results window with the file and its location listed. You can double-click the hfx.exe file on that Window - no need to go to where it is really located.
or
You can bring up Windows Explorer by clicking on the Windows ball as described above and then clicking on Computer on the right side of the screen that pops up. If you start it, you will see an entry called Downloads under Favorites at the top. The hfx.exe file is probably in there (probably!!).
Bill
Steven Antonucci
I don't think Microsoft distributes this way!
steven antonucci
Most MS products are updated through automatic updates (you don't need to do anything to install them). I'd be suspicious about this file...
steve
They do sometimes *LINK*
Dan Donaldson
Here is the page about the fix.
MS hotfix
This is getting worse, Help!
OK, I downloaded a file and It said it was a ZIP File. I put it on the Desktop to unzip. They sent an E-mail with a Password. I copied and pasted the password. It asked where to put the files. I said Desktop again. It said unzip was successful. BUT Nothing showed up. No new files. I went to SEARCH and It can't find hfe.exe.
Then I went back to Microsoft to download it again but got entirely befuddled. I thought I was looking for service pack two for Office 2003, but there is a service pack three. So, why would I download two if there is available.
Beats me. The other problem I have is that the flash that pops up won't let me copy the language. At least not cut and paste it.
ebd
Re: This is getting worse, Help!
ebd
Do install SP2 before SP3. You might bugger things up by installing out of order. Service PAcks are not necessarily backward inclusive.
Grant Wilkinson
Barry
Where are you getting these files? Microsoft does not use Zip files for service packs for Office 2003. The files are all .exe files, which will run and install the SP automatically. I have them all. I just checked on the MS site and and confirmed this.
Post the URL where you found the sp files if you like. Then I, or someone else can look into this. In the meantime, I would suggest that you stop working with these files. It's your call, of course, but there is no way that these password protected files are from MS.
Check Dan's post.
Check out the site posted by Dan Donaldson above. His link takes me to the place I got the files. At least I think it does.
Re: Check Dan's post. *LINK*
Grant Wilkinson
Barry
OK, I can see why you are having problems. That link is to a Hot Fix page. You don't need a hot fix for what you are doing. You just need service packs.
I'm including the link to it. You don't need to install SP 2 first. You will see on the page that SP3 is cumulative.
Click the download button, tell it to save to your desktop. After it's downloaded, just double click the icon on your desktop. It will install.
Office 2003 SP3
I downloaded it and tried to run it. A pop up came up and said The expected version of the products were not found. And then it just quit.
Might be time to buy the upgrade. What version of Office is set up to run with Windows 7
office version
Grant Wilkinson
Barry
That would seem to indicate that you are not running Office 2003. The SP that I directed you to is for Office 2003. I pointed there because in one of your previous posts, you said that's what you are running.
As for Windows 7, I am running Office 2003 under Windows 7 on several machines, both 64 bit Windows 7 and 32 bit Windows 7, with no problems at all.
If you are sure that you are running office 2003, I would guess that it has gotten corrupted somehow, since the SP does not recognize it. Your best bet would be to completely uninstall it, re-install from the media, then install the sp3. If you are not sure that you are running office 2003, open any of the apps in it, Word, Excel, etc, to to Help, then About. The window will indicate what version you are running and if you have any Service Packs installed.
OOps!
I have a 2003 box and 2002 Media. My son traded boxes with me.
Micorsoft Office XP professional
Sorry aobut that, Thanks for the help, What now?
Re: OOps! *LINK*
Grant Wilkinson
Here is the latest sp for office xp. It's also SP3 and includes all the previous patches and service packs.
office xp SP3
Thanks, I've been a PITA and you've been big help
Re: Thanks, I've been a PITA and you've been big h
Grant Wilkinson
No worries. That's what we're here for.
