We value your privacy.
I have to do some eave trough around a bay window, so I have 2 inside & 2 outside corners at that weird angle approx 135 de. I really don't know what to do. Of course I know what it should look like & even have kind of a picture in my mind of how to achieve it, but cutting those angles & making it look really good I can't see myself executing better than a D-.
Somebody tell me there is an easier elegant method?
I am not sure I can help at all, but it would help to know what material your eave troughs are made of. Locally, I think we call what you are talking about "gutters". They are most often made of metal such as aluminum, galvanized steel, and copper. It seems to me that in the parts of the country where they are called eaves trough they are sometimes made of wood.
It would help to tell us what you are working with.
Most rain gutters are put on the faisia of your main roof eaves (soffit) that is above the bay or bow window. The small roof area formed on the bay window is usually not enough water to worry about. If you have no overhanging eave then you can also install a diverter on the roof that carries the water from the roof over to the gutters on either side of the bay window, if the bay window is boxed all the way to the facia of the main roof.
Does the water from the small bay roof cause some problem with a deck or something that splashes back on the siding?
If you really need "gutters" on that little roof, go back to the borg and ask for "joints" at the given angle [which you should measure accurately]. You cut your extruded material to the bisected angle (in this case 67.5� mol), then either snap the joiner onto both pieces at the miter or slide each piece into the preformed corner. Last step is to rivet with 2 pops on either side of the joint and silicone the seam and the pops. If the borg doesn't have the material, call a "gutter guy" in your area.
the roof on this bay is not a separate roof. It's part of the overall roof, a 20 ft rafter on a 7/12 pitch in Ottawa. We get 5 to 10 ft. snow here. Alhough I didn't think about the diverter, I don't believe it would work here.
I just spoke to a custom copper guy who is going to look at it that I know and does excellent work?
You have a Ogee gutter , that's it's correct name and you can buy inside and outside preformed corners at the same place.
Pop rivet it like Mark suggests, forget the Silicone and with a small gas torch , sweat the inside joint area so the solder will run under the joint , hang it with gutter nails and ferrules and your done.
Reading your other post, you indicate this roof is apart of the main roof. Doesn't that mean that the front edge is level left to right, but the two angled sides are slipping down from the eave of the "house" to the lower eave of the bay window. (Or bay "area" if someone insists that a bay "window would have a separate roof.) If this is true, you would have to have the downspout(s) located on the bay area because that trough would be the low point. It also means the angles would be compound angles.
I can't help you with the cutting the odd angles in the gutter, I don't know how the pros do it or even if they do it in aluminum gutters. I believe I have seen it in copper gutters where they were cut and soldered. Since you can't solder aluminum, I can visualize doing it with pop rivets,l but cannot recall ever seeing it.
Check with a supply house to see if the proper angles are available.
As a Home Inspector I see lots of these windows without gutters. Depending on how big the roof area is above the window and how wide the over hang is and other variables such as wind direction there is often damage on the bay area. A diverter will help, but the rain that falls on the roof below the diverter still runs off onto the windows and surrounding trim.
Thinking about this. If the two sides are compound angles it would be a lot easier to put the gutters on the main house and a piece on the outer face of the Bay area. Then you can install short diverters on either side to send the water above the angled area into the gutter on the bay.
