Blum Tandum undermount fixture
David Brown
Hi,
I am doing my first project using the undermount Blum tandem slides. Real nice unit, question is the drill fixture for the orange lock pc that mount under drawers. They want $55.00 for it. I have 3 drawesr to do. Can I fudge it or do I need the $ fixture?
Thank you
Re: Blum Tandum undermount fixture
Moses Yoder
Moses Yoder
It is fairly easy to just set the front clip in the corner of the drawer box and use a small drill bit to predrill the screw holes; you don't need a jig for it.
DizD
I used undermounts for the first time last year and mounted 11 drawers without the jig. I put the lock piece on the slide and marked one hole w/ vix bit and screwed it in. Then carefully checked the operation. If everything worked, I put in the other screws. If it needed adjustment, I reset it and used another hole.
Jim Dillon
David,
I agree with the other posters. I have the Blum guide plus several others (hey, I rationalized a LOT of unnecessary expensive gadgets when I did my kitchen figuring I was saving so much money :D ). While the guide makes life easier, you sure don't need it. Those Blum Tandems are really, really nice and I still marvel at how nicely they slide. In my case, the first install went slowly because I didn't want to screw up. After that, it was a piece of cake. Have fun!
Jim
Dave
Thanks and more Blum questions
dave
thanks to all, now I will push my luck!
as my first Blum tandem experience, I am doing full inset doors. I have the correct hinges, and bought the 3mm height plates, as the face frame overlaps a little. Now I see I have more like 1 to 1.5 mm overlap, so I am thinking I may need the zero height plates and then a homemade 1 mm shim? or will the hinge
adjustment allow for this error?
again, thanks to all
