Way OT: Removing inside rear view Mirror?
Jesper, Denmark
Jesper, Denmark
I need to remove and re-locate the inside rear view mirror in the car. It is in my way and can be relocated an inch or so higher, which will be a great improvement.
The mirror is glued to the inside of the windshield.
There is lotsa information on gluing it back if it falls off, but nothing about how to remove the old one without damaging the windshield.
Anybody been there, done that?
Thanks in advance, guys and gals.
Re: Way OT: Removing inside rear view Mirror?
Keith Newton----Little Rock, Arkansas
I'm assuming that you don't need to know about loosening the little set screw and sliding it up the dovetail.
Did you find the kind of glue to use for putting it back on. If it is a cyanoacrylate, there is a solvent which will dissolve it. You should be able to find that at your local hobby store where they sell model airplane kits.
But you should check with a windshield glass place. They probably have to take the mirrors off of every old glass when they replace with new.
John Veerkamp, Western Mo
Acetone will dissolve the CA used to afix the mirrors. Remove the mirror from the base and then soak a rag in the acetone and try to keep enough solvent on the base until it loosens. Hope this helps.
John
John McGaw
Every time I've had one fall off of its own accord, it has been when it was incredibly hot and sunny and the vehicle was closed up. So, given Denmark's weather, you might consider a drive to Spain this summer. ;-)
Whack it with a hammer?
Jerry Nicholson
Heat
Neal in San Jose
I had a windshield replaced, and mechanic put the mirror on the new windshield WAY too low. I complained, and he was able to pop it off using a heat gun and glue it back on where I wanted it in about 5 minutes.
