Have a question? Ask Woody!
countertop lip
countertop lip
countertop lip
mike mcnerney
I am doing new countertops for a customer & she asked me if I could do some kind of lip right where it comes up to the stove in order to minimize spills going down the stove. It's going to be a typical post formed top with a standard finished end where it meets the stove.
But it got me thinking & I thought maybe a piece of stainless around 1/16" thick & nicely rounded on the top, then mounted about 1/8" above the top surface. I realize it still has the potential to have little crusty stuff build up in there, but...
Anyone ever come up with an elegant solution?
Mike McNerney
Re: countertop lip
Re: countertop lip
Steve in Phoenix
There are ranges that have tops that overlay the counter edge, eliminating the gap. I think it's called a slide-in range.
Assuming it's ok to buy a new one!
Re: countertop lip
Your plan sounds doable
Re: countertop lip
Re: countertop lip
FredD
If a slide in like steve suggests is not in the budget, then assuming you have a finish top 36" from the floor , you could either raise the range by it's leveler feet if it has them or block it up so the range top would about a 1/4" higher then the counter. Just a thought, mind you.
FredD
Re: countertop lip
Re: countertop lip
Did one many years ago that had the wooden edges. At the range we glued a piece of matching wood to the ends of the counter top next to the range. that piece and a 1/4" cove on the counter top side and the range was a slide in. It worked great and the client like it. The problem was that it was oak and got to looking pretty cruddy after a few years. Old food as a grain filler is not decorative.
I think your idea would work better. It would still allow for stuff to run down the side of the range, but at least you could clean up the counter top without pushing more into the crack.
Re: countertop lip
Re: countertop lip
Did one of those years back. I had put in ceramic tile counters, but needed to dress the edges that butted to the range. Got some stainless 1/4x3/4 "L" molding, cut notches in the long arm, laid the short arm on the top and gently peaned it down around the rounded front edge tiles. Beded with clear silicone to seal the top, then put a few brads into the ends of the substrate. Made a nice finished edge against the appliance.
Re: countertop lip
PS
I wouldn't be too surprised to find a ready-made metal edge molding for this very application. You might check with a fabricators' supply or appliance store.
