THE WOODRAT IS BACK!
Wood preservation
Wood preservation
Wood preservation
royalcrown
Hi, I have a piece of wood that still has bark on it. It is a cross cut board about 3' x 2' with the bark around the edges. I was wanting to know how is the best way to preserve it with the bark on it. To let the grain pop and let the bark still show its beauty.
Re: Wood preservation
You'll have a continuing issue with bark because it is inherently weak with little or no structure. You can, however, increase its strength by taking a page from the turners' trick bag. Assuming that your bark is solidly bound to the cambium, you can saturate the bark layers with very thin cyanoacrylate [super glue] that you can get from turner's supply vendors. You can also use water thin resins, either epoxy, urethane, or polyester, that are sold for wood restoration; West System and Polyall 2000 come to mind.
But
Even with these additives, the bond between the bark and the sap wood at the cambium will always be weaker. You might consider carefully removing the bark such that you preserve the "live edge" of the cambium for the look you want. Google "Nakashima" and look at how he used the live edge on his slab pieces.
