chair caning repairs
Jack Guzman from Maine
I am repairing the broken back on a caned chair. The field is woven cane held into a groove with a strip of cane spline. I got instructions on how to replace the old material with new but no clue on how to remove the old. I tried soaking the old spline with hot water and prying it out with a bent chisel made for the job but it is a struggle. Does anyone know of a way to do this that doesn't require cursing? thanks---Jack
Re: chair caning repairs
Roy C. Gryder
Jack, There is no way that does not include some foul language. But, a blade type cutter in your Dremel tool or Rotozip helps. Very carefully cut a slot down the center of the spline then grind a 1/4 inch chisel down to size to remove the remainder. If you have time and wish to do so you can order a chisel made to do this from PeerlessRattan.com. Also, the glue in the slot can sometimes be softened by soaking with vinegar. Be careful using vinegar on light colored woods.
Mrs. G. and I have dealt a great deal with the folks at Peerless Rattan and they are good to do business with. Tell them I sent you. R.
Hello Roy,
I got the chisel you mention(or one similar) at Lee Valley.I'll give the vinegar a try and thanks for the recommendation . I'm going to contact that Rattan place. It sounds like they might have some things I can use.---Jack
George Colonel's Workshop-Havertown PA
good Afternoon Jack,
I used to do a lot of chair caning/cane removal. I started with a sharp utility knife and applied it to each side of the spline, severing the shellac/varnish. If you are lucky you willk be able to lift out the spline as you tap the cane chisel underneath the spline run. If the spline was installed with "too much enthusiasm", you are in for a nasty dirty job. Sometimes vinegar helps a lot. Make sure you thoroughly clean out the groove, and be sure to use the correct size spline during recaning.
George
enthusiasm
Hello George,
I'm afraid the person who installed this cane was enthusiastic.The good news is I got it out. Now I just have to clean it up.I'll be using heated vinegar tomorrow. I used a caners chisel and worked the spline out dry an inch at a time. It wasn't too bad once I got the feel for it. Thanks---Jack
Re: enthusiasm
Bob Entwisle in NJ
Jack,
Clean the old glue out with enthusiasm.
And since sooner or later all caned chairs succumb to a 5 or 10 year old standing/putting a foot through them, do the next guy a favor and glue the spline in with hide glue.
Bob in NJ
Re: enthusiasm
Since I plan on doing furniture repairs for quite some time all I use now is hide glue.---Jack
