flossed the Ipe deck today
Dave
dave
My 4 year old Ipe deck needed a new coat of stain, been doing it every year, the Ipe does not absorb stain and winters are rough on it. Holding up great screwed, glued, and plugged 100%
When I built it I started out with real small board gaps and recognized my error 1/3 of the way thru it and opened up a little.
Today I did soemthing about it, I use my PC 4 1/2" worm drive say and sliced open the small / tight board gaps,
worked gret!gaps look fine!
Re: flossed the Ipe deck today
Question about staining ipe
Hi Dave,
My ipe deck has weathered a bit, too, and I'm wondering how to get back to the rich brown color without sanding first. Stains and oil finishes don't get rid of the gray; they just make it look darker and muddy. What kind of stain are you using? Do you use other finishing products on the ipe?
I installed my deck boards with Eb Ty fasteners, so flossing isn't an option.
Re: Question about staining ipe
FredD
Check out "Sure Wood Systems" Ellis , looks good, is expensive and best of all the last time you have to mess with your deck finish.
FredD
Clint Searl
Clint Searl
I may have mentioned this a while back, but to refresh my memory, I like Olympic "Australian Timber Oil." I made a picnic table top out of ipe decking that I finished with it. After a couple months in the summer sun it looked so good, I brought it inside for my computer desk. It richened the tone of the natural ipe.
Clint
Dave
dave
Hi Ellis,
short answer, try oxalic acid wash, Woolrich make one you may find at Lowes. It brightens the wood, but if well weathered, my thought is sand then Oxalic acid, but give the wash a try. I rented a floor sander when I first built the deck,
Long version:
I started this am finishing the "flossing" then I brought out the Ridgid (bosch ) 6" ro sande, I did all 463 sq on hands and knees, then I washed and scrubbed with bleach 2 cups, and Jomax, 1 cup, and water w/ scrub .
then I let dry, then I did the Oxalic acid wash, then rinsed.
Then I cut lawn, then I stained railing details and outer wraps, tomorrow is the rest of the staining.
I am used a TWP product. There is a Guru named John Hyatt, who is a real fine gentleman, and assisted me in my Ipe project. He posts on some of the contractor forums, sometimes Gardenweb as well. He is THE man on IPE
Dave
Yes, I'd like to learn more about John's ipe expertise. Why not invite him to join the thread?
I sanded this floor once already, with a rented rotary floor sander. It went fine, but it was a lot of work. I don't do hands and knees any more than I have to these days. I want to figure out a maintenance schedule that will save me from future sanding. I'm using Australian Timber Oil now, but I think it needs to be recoated every few months. If you let it go a year, the exposed wood weathers. On the covered section of the porch, it deteriorates at about half the rate.
Once it goes gray, I suspect sanding may be the only way to get back to fresh looking wood. So it goes.
Dave
dave
Hi Ellis,
I stain mine every year, and under the gazebo, it also fades at 1/4 of the exposed rate,
The TWP stain product is the one John likes.
if yours has gone gray I think u are right, sanding is needed.
work safe!
Dave
Suggestion
You might consider Penofin Oil Red-Label.
A bit pricey and fussy to apply - $48/gal, brush on, wait 15, then wipe off - but it has done well on my p-t decking and walks. Non-film forming so you're not put in a situation of having to abrade/strip old finish. I'll get 2 years on horizontal surfaces with little or no variation between direct sun and open-shaded surfaces.
