Conf. table - Revise, reface? (Long)
Henry (Raleigh, NC)
Conference Room table � Revise, reface, refinish?
I am looking for holes or issues in my plan to redo a conference room table. The table is currently a 12�x 4� rectangle. One corner has been water/weather damaged.
Existing construction: The top is about 1 �� thick. The surface is a laminate (Formica type) glued onto two stacked 1/8" plywood sheets. The structural core is a series of 1� thick solid wood pieces glued together. The bottom is also has plywood on the structural core and then a laminate layer, presumably to balance moisture uptake. There is a solid wood edge band on all sides.
This is a very hefty and solid table that has served very well, but it is both showing its age and has some water damage. The enclosed picture shows both the damage and the table construction.
Refurbish plan:
Here is what I am thinking of doing:
1. Remove existing laminate top and repair any laminate damage on bottom
2. Patch any remaining issues in the �� plywood top.
3. Reshape the rectangle by cutting the long sides of the rectangle into a gentle arc. This will likely remove most of the water/weather damage on the one corner.
4. Edge band with several strips of 1/8� maple (1/8� strips for flexibility to follow the arc), with the top with the existing plywood surface.
5. Reface the table top with �� cabinet grade maple plywood. I haven�t decided on the design, but I�m thinking of a diamond grain pattern with 4 pieces of plywood. For a 12� table I�d need 4 pieces unless you can get 12� pieces of �� plywood.
6. Inlay solid wood strips (maybe contrasting?) at the intersections of the plywood, with either a diamond or an oval at the center
7. Edge band one with a 1/8� strip of maple, this time flush with the new plywood top, and the soften (round-over) the edge with a router and sanding.
8. Shellac base coat to seal everything
9. Polyurethane top coat(s).
Questions � Concerns
1. I know with a proposed structure of the existing laminate on the bottom and a new top of plywood/polyurethane that there is by definition an imbalance. Should I remove the laminate from the bottom of the table and coat with poly?
2. I have done some inlay work on smaller furniture pieces by adding contrasting 1/8� or 1/16� solid wood strips into table lags, but I not done anything on this scale. I�ve certainly not done any larger inlaid piece (4-6� across?) like I am considering in the center of this table. Are there specific considerations that I should be taking here? The longest individual inlay will be just under 6� long.
3. Is there anything different about inlaying strips into a plywood surface rather than a solid wood surface? I realize that with the surface veneers of plywood that I�ll have less leeway in terms of sanding the surface level � which is why I typically leave the inlay materials proud of the surface and then level.
4. Most important � What might you do differently? Is there anything I have missed in my plan?
Note that the much simpler backup plan is to simply repair the damaged corner and reface the table top with laminate.
Henry
hwynands@ieee.org
Re: Conf. table - Revise, reface? (Long)
Jim Rahbe, Bedford Texas
Only OT posts get a reply :-)
Henry,
I like the idea of rounding the corners just to get rid of the standard rectangular shape, but I�d be wary of a plywood top. I don�t think plywood would be able to stand up to the abuse that a conference table would normally get. If you�re doing this for fun, or to show off your woodworking skills, then have at it. If you�re doing this to make a usable conference table, then I�d use laminate. Not only that, you can get laminate in 12� lengths.
Jim R.
Big job
This could be a fun project. Here are a couple comments on your plan:
If the arc is gentle enough, you can probably get by with thicker edgeband, as long as it bends easily to the curvature with only hand pressure or light clamping. I question why you need this step, though. The final edgeband (your step 7) should do the trick, although I'd consider making it thicker than 1/8".
12' pieces of 1/4" plywood are available, although maple wouldn't be my choice for a quarter-match as its grain is pretty bland. As an alternative, you could get some fancy veneer and lay it up on your existing plywood substrate, provided the substrate is flat and sound after you repair it. 12' is pretty long for a one-piece veneer job unless you have a really big vacuum bag or a buddy with a long hot press (or cold press), or unless you feel comfortable with hammer veneering. A good alternative would be to lay up four pieces of door skin (nominally 1/8" plywood) with your face veneers, using some lowlier veneer for the balancing layer on the bottom. This gives you nice flat stock to match up to make your pattern. You'll still have to glue the pieces together on the table, so again you have to decide on a suitable adhesive for your capabilities. I think it's too big a job for hot hide glue. This is one situation where contact cement (did I say that?) might not be the worst alternative if you don't have any means of pressing something this large. Never use contact cement to glue veneer to a substrate though. I never did it this way. I used to have six or eight long 6x8 doug fir beams that I used for pressing pieces this big. You need a screw press or some serious clamps though, along with several layers of thick waxed particleboard to use as cauls to distribute the pressure evenly to the glue line.
A thicker banding would provide more protection for the edge and give you a little wiggle room on the radiusing operation.
Polyurethane is self-sealing.
I don't think this will be unbalanced. It's the glue lines that count, and those would be more or less identical. Poly (or any other finish) is not totally airtight, so if you remove a glueline from the bottom and replace it with a permeable finish, it will actually be worse.
You shouldn't have any trouble unless you try to inlay very wide pieces of overly thick wood or veneer. Keep the inlays under 1/8" in thickness.
Just be careful. I'd suggest routing the depth very accurately with the inlay just a few thousandths above the surface. And, when you level it off, use scrapers to do the initial flushing of the surface; don't use an orbital or belt sander except at the final fine grit stage, as it will dub over the edges of any proudness (?) of the inlay and cut into the adjacent face veneer.
Personally, I'd use another wood besides maple. Unless you plan to dye it to a tasty, deeper shade, it's going to start looking yellow in no time.
Not much challenge there, eh? :)
Thanks - revised plan with 'customer' input
Henry (Raleigh, NC)
Thanks for the responses.
This table is for a non-profit that is moving to bigger space. I spoke with them about the surface choices. Laminate it is - for durability reasons. This will be both a conference table for a monthly board meeting, as well as a lunch table in the break room.
I have in fact found a 12' x 5' piece of laminate at the Habitat ReUse Center here in Raleigh. Now the only choice is whether to reshape to gently curve the sides, or try to fully repair the damaged corner.
I will incorporate your suggestions into changing my edge banding plans.
Thanks
Henry
hwynands@ieee.org
Re: Durability Suggestion
As you're going with laminate, reduce both your length and max width so that, with the edge banding applied, you get a slight overlap all around with the laminate. Apply your banding and sand flush with the top. Now apply your laminate and trim back flush with the banding. Lastly put a nice 1/4" champher on the top edge. You'll have a nicely formal edge and the banding will protect the edge of the laminate from nicks and bumps.
