Fastening flashing on wood?
I'm building these entry "fences" for a friend. I am building them out of cedar.
They will be sitting on mulch - so they will be down in the wet stuff. I was contemplating putting some aluminum flashing on the places where the cedar will contact the mulch or ground. I am painting the cedar with exterior paint. I am priming the cedar first.
The larger column will be fastened to a pressure treated post that will have its lower portion sunk into the ground (with concrete).
Should I use flashing on the bottom of the cedar columns to protect against moisture or should I just seal it well?
TIA
