Have a question? Ask Woody!
OT, Play with a Blood Pressure Meter
I have been playing with my blood pressure meter. Does anyone know if they are reliable? I have a RelyOn one that is either battery operated or you can plug it in.
I find that the readings vary a few points if you take it over and over. Is that normal? I find blood pressure goes up during the day. Lower in the morning and higher later on. Wonder if that is the caffeine?
I have observed two things I think are interesting. If I lay down and take it it lower than if I sit up. I think that's correct and understandable. The two things if find interesting are that if I am laying down and rest the arm with the cuff beside me the reading is substantially different than if I raise my are and point toward the ceiling. Does not seem that that few inches of elevation would have much effect, but it does. I suspect that it is not because the cuff is raised above the body, but that the rest of my arm is even higher.
The second observation is that if I sit up and take it it marks a big difference if I sit up straight verses slouching. Slouching (really bad posture) raises the pressure abut 20 points on the top and ten points on the bottom.
I also noted that sitting up raises my pulse rate about five beats over just laying down.
So, the point is, When you have your blood pressure taken, sit up straight.
Re: OT, Play with a Blood Pressure Meter
Re: OT - Is Der a Doctor in The House?
Seems a bit erratic, Barry. Perhaps you should be addressing your "question" to someone with the real training and experience to comment properly.
Howard Norman
I have used an A&D blood pressure monitor for over ten years now. When I first purchased it I took it with me to the doctor's office several times. It was dead on with the unit at the doctor's office. I haven't done that for several years so can't comment if I would get the same results today or not. The doctor and his nurse were very impressed which made me believe that is not the norm for the consumer BP measuring systems.
As I understand the variation in BP by sitting/laying down is normal as well as the position of the arm during the measurement. I certainly am not, nor do I play one on TV, a MD but as one who has been on BP medication for many years I have acquired some knowledge on the measurement.
I would strongly urge anyone with a home measurement unit to take it to their doctor's office and compare the measurement between their machine and what the nurse reads for BP.
Most blood pressure meters (or cuffs) are quite reliable. It is usually the person who is using the instrument is the problem. ;) . Seriously though, if you have questions or concerns about the reliability or how to use them - go to a nurse or medical health professional. I would also recommend "calibrating" your meter against another one - like at the doctor's office.
The readings often vary if you take them over and over. You are squeezing your arm over and over. At our age - the veins don't bounce back that quick. Standard practice is to wait several minutes or switch arms (and rest between arms). Your blood pressure goes up as you move around. My resting BP in the morning is typically 105/65 with a pulse rate of 55-60 (yes, this is unmedicated). Later in the day it will get higher.
You should not raise the arm above the heart while taking your blood pressure. It should be about at heart level.
Good posture is important - when you kink a hose, the pressure goes up - same thing if you kink a vein or artery.
Addy protocol - stint as an EMT and first aid responder. Also having to teach the first aid classes for a few years.
steve mackay
I just went through the whole process of getting set up for BP meds. Luckily the Doc hit type and dosage on the first try but there was still a month or so where I needed to take BP a couple times a day. The advise above to take your unit in to the clinic is right on. It will not only verify if its "in the ball park" but, for me, give you the confidence to feel comfortable with the whole process. My problem was that ANYTHING tends to goof with my BP. From pizza for lunch to just being in a bad mood. In the end game record your numbers acurately and let the Doc evaluate the point spread.
John E in SC
The above posts are right on. (I'm an MD, but this information cannot be construed as medical advice, etc. etc.) BP will vary with position, both of your body, and of your arm. Typically, BP will drop slightly and pulse will go up slightly when going from lying to sitting to standing, but lots of factors can affect that. Using a home BP cuff, you want to have the cuff on your arm with the arm at rest, and the cuff should be at the level of your heart. Repeated measurements will vary slightly due to compression of the artery, and BP will vary (sometimes a lot) with time of day. Like the others suggeested, I would recommend you take your cuff the next time you go to the doctor to check against theirs. It won't likely be exactly the same, but should be close. Over the years, I've seen many that were good, but some weren't even close. On a side note, I DON'T like those cheapy wrist or finger BP monitors - I've never seen one of those worth using.
John
paul in AZ
As has been said these machines are reasonably accurate [although my first wasn't... but a Microlife that replaced it is OK]. Just check it against an old fashioned mercury manometer to see if the readings correspond.
The machines in the grocery store are DANGEROUS because they are abused and rarely calibrated.
Lots of things will vary BP just as pulse rate can change.
Keep a written record and patterns will emerge.
Add glucose meters too
Bill Turpin in WNC mountains
B. Glucose meters can vary too. Same finger, same prick, same meter, and strips will give readings � 15 points. This is with no fluids, food or activity tested only thirty seconds later. Use these tests as a guideline and communicate with your doctor.
mine doesn't
Bruce, a MN Galoot
a point or two, yes, but not 15.
Listen to the doctor
Bill Earl
As John says, there are many factors affecting your actual blood pressure. There are also many factors affecting the accuracy of the instrument. As an engineer with experience designing pneumatically actuated medical devices, I can mention a few of them:
There are manufacturing variations in the sensors and associated circuitry. Some have been calibrated at the factory and are of an inherently stable design. Some are not. I have seen errors in excess of 10%. Compare your device against your doctor's.
These sensors are temperature sensitive. Your BP cuff may-or-may-not have built-in temperature compensation.
Raising your arm will change the pressure at the cuff. Just considering the hydrostatic pressure, a 12" change in elevation relative to the heart would translate into a change of about 22 mmHg in measured pressure.
Re: mine doesn't
I have experienced this with four different brands of meters over twenty years. I always check them at endocrinologist with the same drop of blood = �4 pts. Maybe I just have fickle blood.
Jesper, Denmark
Jesper, Denmark
All of your results seem to fit with hydrostatic theory.
Don't worry about it.
