Another Veenering Question
Bartstar
I'm having a real hard time cross cutting my veneer. I'm making some cross grain cuts, using a straight edge and a veneer saw. The problem I'm having is at the end of the cut. The veneer is just breaking off at the edge. Any suggestions? Maybe I should cover the area to be cut with blue painters tape before I make my cut.
Thanks
Bart
Re: Another Veenering Question
Back Cut
At the trailing edge with your saw or a razor knife. Tape also helps. Just never "pull your blade into air" where the last layer of wood fibers aren't supported.
Lee Grindinger
How thick is it?
Lee Grindinger
How thick is the veneer you're trying to cut? I found razor knives worked best and I cut quite a lot of veneer over the years, if it's too thick for a razor knife a router or jointer or table saw was my next technique.
Lee
Re: How thick is it?
Bartstar
Hi Lee,
I've cutting some quilted Makore I bought from Certainly Wood - its your typical thin stuff. Question - when you say razor knife, I assume you mean an exacto blade like knife?
Thanks
Bart
Lee Grindinger
Sometimes
Lee Grindinger
I used an Xacto knife for freehand work sometimes but found the angle of attack better in the regular old utility knife, the type with replaceable blades, sometimes called sheet rock knives as well. The key is to make the first pass very lightly so the blade follows the straight edge rather then the grain merely scratching the veneer, then deeper cuts with two or tree total to finish the cut. Tip the knife about 5 degrees away from the straightedge and keep the piece you want under the straightedge since it will be slightly undercut. Practice cuts on some scraps, you should find this much easier than a saw. By the way, I owned a veneer saw but used it only once abandoning it for the razor knife.
Lee
John Luke
Get a wheel type veneer cutter.
Lee Valley handles them.
make a special bench hook
Dick Coers
Another vote for utility knife. If you still wanted to use the saw, you could make a version of a bench hook, but only have the fence the same thickness as the veneer. It's all about supporting the edge of the veneer when the cutting force is trying to pull it apart.
pecker
I always make a few push strokes with the saw, at the end where you're getting your tearout. After I'm satisfied I've cut that end, then I make the long pull strokes for the rest of the cut.
