Steel City mortiser and mortise depth
Stephen Kirk
When using my mortiser I always have to raise up the workpiece as the length of travel on the machine stops way short of the base. I have the cylinder which supposedly helps lifting the bit - could that be limiting the travel?
Just wondered if anyone else experienced this?
Re: Steel City mortiser and mortise depth
There should be a way...
... short of raising up the workpiece. Isn't there some way to lower the head or raise the base? Sounds strange to me.
Re: There should be a way...
FredD
If your Steel City Mortiser is built conventionally , you will find that the lever travel is adjustable and you need to do that.
Look for a spring loaded sideways travel in the lever arm that lets you repositioned the lever when you pull it out so it will be close to vertical or even a bit beyond when you pull it down to cut the mortise.
FredD
Joe in a Cleveland suburb
Hi Stephen.
I have the same mortiser and same problem/question.
I use a block of wood to move the piece up.
I've never been able to figure it out. Seems really odd that you/we need to do this. I don't see a way to make the head/mortiser/chisel thingy go down lower.
I'll be using it soon and will take another look to see if I am missing something obvious.
Joe
Stephen Kirk in Quakertown PA
I was reading around the interwebs a bit and saw some other questions just like mine. I checked the machine and it does look like it's the hydraulic piston arm (which helps lift the head) that stops the travel. This is the black piston like piece to the left of the column. When it bottoms out, the head can go no lower, and this is about 3" above the bottom of the mortiser.
I usually just raise the workpiece up on blocks, but that kind of defeats having the rollers to keep it tight to the fence, or the pull out arms.
My machine came with the hydraulic arm removed. It's a pain to put on, but I think I'll remove it and see how hard the head is to lift. If it isn't much, I may just leave it off.
Re: Steel City mortiser and mortise depth *LINK*
Phil Joines
According to the manual the maximum stroke is 5". If the space from the tip of the chisel to the table is more than that you'll have to use a spacer. There's a depth stop behind the head that looks something like an Allen wrench. Check to see if it's set too low.
manual
FredD
If Stephen takes the time to look at the Manual , page 18 . fig. 11 and 12 he will see what I said in the first post , reposition the handle so you have a longer down stroke. Piece of cake.
FredD
Stephen Kirk
Nah, the handle is OK, I routinely change that depending on what I'm mortising. The "stabilizer cylinder", which is the hydraulic arm type thing on the left of the column bottoms out when the chisel is about 3" above the base of the machine. When the cylinder is removed, the chisel can be lowered much further. The cylinder is added to make raising the head easier, but the downside is loss of stroke length. I'm going to take off the cylinder and see just how much harder the head is to raise, if it isn't a big deal I'll just leave it off.
FredD
If there is a design flaw you should bring it to Steel Cities attention, seems like they would know about it though,
You shouldn't have to modify a new Machine to make it work.
FredD
Hydrolic Strut
George Colonel's Workshop-Havertown PA
Good Afternoon Stephen,
I have a Shop Fox which also uses a piston/strut to limit head travel. It attaches to the body of the mortiser by sockets and ball joints, just like the struts in trunk lid or rear window of many cars/wagons. My machine body is tapped to accommodate the ball joints in two or three locations. Take a look at the mounting positions for the spring/strut in your mortiser. I can't imagine why you'd have to raise the work to make a mortise! Does the owners manual address the issue?
George
Jim DeLaney, Austintown, Ohio
Re: Where is the depth stop set?
Setphen,
Is the depth stop rod preventing further travel? Check out Figure 23 and 24 in the manual.
The hydraulic assist strut should allow full travel.
Jim D.
I think it is a bad design. I have the same machine.
If you look at figure #5 in the manual (link posted in another reply) it shows the piston and its fixed position. The head can only go so far down then bottoms out on the piston.
I have to look at mine again, but it seems really odd we can't make this thing have full travel without the need to lift the stock up on another board, or detach the piston.
Mine also came with one of the stock roller wheels frozen. It doesn't spin. I tried repeatedly to get a replacement from SS without luck.
Otherwise, I like it.
