Steam Bending - Propane BTU Rqmts
Paul Leuba
I am assembling a small steam bending set up for the back bows and arms of windsor chairs. The question relates to how much BTU output is needed for the propane burner to boil 3 - 4 gallons of water in a reasonable amount of time (10 mins or so).
The choices available for internet purchase range from a burner capable of 55,000 BTU/hour (10 PSI regulator) and one capable of 185,000 BTU/hour (20 PSI regulator).
The burners will be used outside. I do not want to purchase one to weak to build and sustain the heat necessary to sustain steam for the required 15 + minutes, and, at the same time, I do not want to purchase a burner much bigger than necessary.
Any advice on this would be appreciated.
Paul in Hunt Valley, MD
