We value your privacy.
I have been asked to put a new "veneer" on some exterior church doors. The original veneer was red oak about 1/32-1/16 thick. We are going to replace it with 1/4" white oak, hoping it will hold up better to the sun and weather. What would be the best glue to use to attach it. Also, any ideas for clamping?
With "veneer" that thick, you're going to have to deal with seasonal movement. That pretty much mandate quarter-sawn stock all around. You haven't indicated whether the door(s) will be wet regularly or their exposure to direct sunlight. The more direct-heat drying you have the more thermal gradients you'll have to deal with. While Titebond 3 may work, it still going to have PVA creep. I'd tend to say 2-part Resorcinol(sp). As far as clamping that large of a "substrate", I wouldn't do anything but vacuum clamping.
As Mark suggests, 1/4" isn't veneer anymore, in the sense that the glue line won't prevail against any differential movement between the substrate and the laminate. This said, if the substrate is solid wood, you can probably get away with it, as long as you balance the construction. This means applying a similar laminate to the inside of the door.
As far as glue is concerned, I'd consider West System epoxy, mostly because that is my personal favorite for exterior millwork.
Regarding clamping, a vacuum bag would definitely be the most efficient way to do this.
I will try to get it thinner if I can get it through my planer without chewing it up. May be a good time to use my drum sander. I will probably lay it up as individual boards, since there are a lot of narrow cross pieces between the windows.
It will be exposed to both rain and direct sunlight. They will be protected somewhat by an overhang, but these are on the south and west sides of the building.
If you laminate 1/4" on both sides of the door, the door will be quite thick. Not only will that add substantially to the weight it may mean the hardware won't work and the hinges may not be strong enough.
I have a Dewalt planer and have planed stuff thinner than a 1/4" by sending it through on a sled. I used double stick tape on the leading end and easily got down to an 1/8" l just used am nice straight flat board as a sled.
I have done it as well in my drum sander. I sanded stuff down to 1/50" (.02") that way.
On a contrary note, I recently rebuilt some doors for my cousin. Hers were severely rotted at the bottom. In spite of my best efforts one of them is coming apart again in a matter of months. I would suggest you consider replacing them. In the end it may be cheaper, easier and better.
Modern high-speed planers can really surprise you. High cutterhead speeds mean that you can get away with planing stock quite thin. The danger, as you get thinner, is that local grain patterns can cause blow-ups you didn't expect.
I suggest you try to plane your material thinner, and have enough extra stock on hand to make up for pieces that don't survive.
they make what they call door skin's My supplyer has all kind's 4x8 and the contact glue Check with a supplyer if you have one close by Just a thought good luck
What is the open time for the West epoxy vs resorcinol?
I'm not sure I can afford to buy a vacuum bag for this project. I won't likely have much use for it later to spend $800+ for one project. If I plane the material to 1/8", could I "clamp" it by putting a board on top and weight it down? How long does it take the epoxy to cure?
Unfortunatley, the church can't afford to buy new doors. These are very heavy, large doors and there are 8 of them.
Del's suggestion about door skins is the way to go , faster, longer lasting and probably what is on it now.
If the 1/8th thickness of the door skin times two raises the door thickness , then you would need to check the lock and hinge and stop rebate to see if they will work,
I removed about 1/8" of old veneer from the outside, so I think I will probably replace it with 1/8" white oak. We aren't doing the inside of the doors this time. BTW, the doors are about 2 1/4+" thick. These are big heavy doors with lots of small windows the entire length so I'm not sure if a skin will work. I may have to break down and buy/make a large bag press, it looks like.
Ellis, what is the open time for the West System epoxy? If I pin individual "boards" with a few pin nails as i go, will I have enough time to place and pin 12 pieces or so before I can get it in the bag?
Randy, Unless you buy the super fast 15 minute stuff, you will have plenty of open time to spread and and get it into the bag once it has been spread. Now, you can't mix a big container, and leave it in a deep cup very long, but once it has been spread, there will be plenty of time.
I usually just use masking tape to hold the parts in place.
Here is a link to the epoxy source that I use. Their price is less than half of some of the more popular brands that spend a lot of money advertising to the public.
I have been vacuum-bagging since the late eighties, and use epoxy as my standard glue. In teaching and encouraging other woodworkers to give it a try, have offered advice into ways to just use their compressor with an open tank with a hose plumbed into the intake.
However I have been wondering for some time about whether a shop vacuum would do the job, so I just did a test with my Sears shop-vac. I cut two 12" x 12" plywood squares, then surrounded them with cardboard sandwiching my bathroom scales in between. I was really surprised to see it hit 175# per square foot.
Epoxy doesn't need lots of clamp pressure, it only needs to make full contact, so this is more than enough pressure for bagging. With the kind of volume of air this would provide, I am sure that one could tape together a poly film using two sided carpet tape around the edges. A 3' x 7' door would have 3675# of clamping pressure, which might be enough to collapse a cheap hollow-core, so a leaky bag might be in order if it wasn't solid.
