OT Help with Microsoft Please
I need help.
I just bought a new computer. Came with Windows 7.
I installed Microsoft Office for XP.
Now when I move to different programs (Adobe, Outlook, IE etc. and try to use cut and Paste I get a message. "The Office Assistant Requires Microsoft 2.0 or Later. The product is available on the Office System Pack." and then the only choice is "OK". (I think I got that right, but they would not let me cut and paste that piece of corporate brilliance.)
(I wonder if they have any idea how stupid that is or at the least how stupid it makes me feel? Is it a good idea to make your customers feel stupid?)
I looked at the disks that came with Office but i don't see anything labeled Office System Pack. Of course Its hard to read those stupid holograms.
Can somebody tell me where to find Office system pack and what to do? Give me a clue I can use.
Re: OT Help with Microsoft Please
JimG
Take a look here.
http://support.microsoft.com/kb/969168
Jim, Where do I put it???
I followed the link carefully (I thought) and downloaded what ever it said, but it went into the root directory. It appears to have had no effect. Where should I put the download? I loaded Office right off the disk and put it where ever it said it wanted to go. I don't even know how to find the name of that file.
Might be easier to use Office 2007, but since I have 2003 I figure 2011 is not far behind and I will have to start all over.
Thanks.
Miss Microsoft
iew
Since I have upgraded to Mac I have never looked back. I just got tired of all the problems like you have. Just turn the MAC on and it works, every time. I still have a PC laptop that I use sometimes, runs XP and it will never run anything else.
Re: Jim, Where do I put it???
JimG
Barry,
I have XP. I extracted the zip (double click the zip file), but the files that comes out are not meant for XP. However, the msu extension is the installer (msi in XP) for Windows 7, from what I read. So you should be able to double click the msu file and follow the install instructions. If it requires a password, that would be with the email MS sent.
Jim
Jerry Nicholson
I am using Office 2003 on Windows 7 (Home Premium) and I don't seem to have any problem (yet!) copying and pasting. What Adobe product are you using? I tried it with Adobe Acrobat and Adobe Photoshop Elements 8.0, although Elements has a few quirks of its own. I am about to build a new computer with Win 7 and was going to install Office 2003 because it is compatible with Office 97 (which does not work correctly on Win 7) but if there is a potential problem I could install Office 2007 or Office 2010, neither of which I like. If Office Assistant was an option on Office 2003, I probably didn't install it because I always hated the Office Assistant in Office 97 with great passion. When I get the new computer built, I will probably uninstall Photoshop CS2 from the XP machine it is on and install it on the new Win 7 machine.
Woodworking connection for this topic: I use my computer to create my drawings!!!
Jerry
Sgian Dubh
" Office 97 (which does not work correctly on Win 7)"
Jerry, what problems are you aware of with Office 97 working in Windows 7? That's the set up I've had for about a month now, and I've not so far experienced any difficulties with Word, Excel, Publisher, Outlook or PowerPoint. I'm using MS Office Professional as well as Windows 7 Professional. I also downloaded and installed Virtual XP for a couple of programmes I couldn't install on Windows 7, but worked happily in XP, eg, an old version of AutoCAD and QuickBooks Pro 2006. Slainte.
Jerry Nicholson
I was going by Microsoft's compatibility list which says that Office 97 and Office XP are not compatible with Win 7. I installed Office 97 on Win 7 Beta and it seemed to work but I didn't really exercise it. That was several months ago and my memory isn't worth spit but I think my Excel VBA macros did not work. I saw a comment somewhere on a forum that said installing Office 97 would cause some Win 7 function to quit working. I tried the Office 2007 and Office 2010 demo programs and felt like they provide a really clumsy way of doing things that are easy in Office 97, and they won't run Office 97 macros. I guess I should do a test install of Win 7 with Office 97 (no activation and no network connection) and actually run Office 97 through its paces. OpenOffice is a free and somewhat compatible alternative but even when I run Linux I prefer Office 97 (installed with CodeWeavers CrossOver) to OpenOffice.
Jerry
Jerry, I have Windows 7 Home edition and Office XP. Not sure about the various designations.. The windows came on the computer, I installed the Office.
The Adobe is Acrobat Standard, version 9.
It seems to be a little glitchy. Little weird things happen. Like today you have Spell checker while typing an E-mail in Outlook, tomorrow maybe not.
When I loaded Office, Word had little right angles at the top of the page that appeared to designate the upper corners of the text. I never saw them before. Then I down loaded the Assistant thing and the Angles went away. At least they were not there last time I looked.
A message comes up in the lower right complaining about something to do with the color scheme being compatible. No idea what that is about.
I tried to keep this simple. The advertise it as being simple. Not so much. So far Quirky would be a better description.
The patches thing is driving me Crazy, but that's a short trip. I have no idea if it is working or not. Should I put it in the directory with Office? How would I know?
On my previous computer the Kodak Easy Share pictures were in MY Pictures, This time, God knows where they went. Why would they change that?
Bill Howatt
Did you execute the patch file you downloaded by double-clicking on it and following any screens that came up? It will put the required files where they should go when it executes. The file you downloaded is the installer and its location is not critical. Once it is run you don't even need it unless you want to do it again at some future time.
Bill
JimG
Barry,
You should have gotten an email from MS for the hotfix. I believe you downloaded it. It should be a *.zip.exe file. Double click the .zip.exe file and it should extract a text file and the *.msu file. You should be able to double click the *.msu file and it should install the fix. Probably need to reboot.
Alternatively, someone mentioned they did not install the Office Assistant. You could try going back into the Office setup and see if you can remove the Assistant.
Jim
Outlook doesn't play well?
Jerry Nicholson
I did a little more digging and it appears that Office XP should be compatible with Windows 7 except for Outlook. According to the information I found, Outlook 2002 and Win 7 do not play well together and Outlook should not be installed. Maybe that is why I haven't had trouble with Office 2003 (Yet!) on Win 7 - I didn't install Outlook.
Jerry
Re: Outlook doesn't play well?
Sgian Dubh
Jerry, Outlook works very well indeed for me in Windows 7. Perhaps that's because it's the Outlook that came in MS Office Professional 2007. I prefer Outlook (which I've used for about three years at work) over Outlook Express which I used on my home computer. That is just as well perhaps as Outlook Express didn't come in the MS Office 2007 package, and apparently I couldn't even install and use an old version of Outlook Express on my home computer if I wanted to.
Thanks for your earlier messagewith the additional information by the way. I have to admit that some of it was above my knowledge base and experience, but hopefully others will benefit more than perhaps I can. Slainte.
Jerry Nicholson
I was referring to Outlook 2002 that came with Office XP as not playing well with Win 7. Since Office 2007 is on the recommended list for Win 7, I would hope that all of its elements would be compatible with Win 7. I have never used Outlook at all and I recently quit Outlook Express (Which hasn't been updated for several years) for Mozilla Thunderbird Version 2.x. I do realize that Outlook's functions extend well beyond those of Outlook Express. I find computer tinkering to be a great source of mental stimulation, especially for an old geezer like me!
Jerry
Sgian Dubh
I find tinkering with things like operating systems in computers primarily a great source of mental irritation Jerry, but I appreciate your input on this topic. I seldom get involved in these off-topic threads here at WoodCentral, but for some reason I picked up on this one. I suppose if I admit the truth, my posting on woodworking subjects here has dropped off considerably over the last five years or so; but I do sometimes respond or contribute to threads, and generally when I do, I think my contribution is usually fairly involved. Slainte.
