I need a chunk of Cherry
Joe in a Cleveland suburb
Hi all.
I'm about to make an end table for my son similar to the tables Christian Becksvoort made in FWW a couple months ago.
I have lots of cherry for this little project except for the legs. Also, I no longer have a vehicle capable of hauling enough wood to make a 2 hour trip to Amish country where I (used to) go for cherry.
I found a piece on eBay, ordered it, paid for it, then received an email (and refund) from the seller telling me he couldn't find it... Woodfinder of course provides lots of companies to call, but this is such a small order.
I need a nice clear no sapwood piece of cherry to make 4 legs (well, 5 because I always screw one up on the lathe...) that are about 1-1/2" square by 28" long.
Could somebody suggest a site that offers small orders like this?
Thank you.
Re: I need a chunk of Cherry
Northwest Lumber....Indy *LINK*
Check with Northwest lumber in Indy. They always have 3"X 3"X 36" clear FAS cherry blanks on hand. Yes. they ship. Here is a linky...
Good luck.
T.
Northwest Lumber
You want some 8/4
I wouldn't try to find a thick blank only to bandsaw it into quarters for legs. Get yourself a piece of 8/4 FAS cherry that is about 8" wide. Rip your blanks out of that. If you only need 3 feet of it and don't want to buy an entire board, call a retail hardwood dealer [Woodfinder probably has several in your general vicinity] and see if they can accommodate you. If you're making two end tables, you'll need at least 5 feet of wood anyhow, so maybe an 8' piece would suit you fine.
Re: I need a chunk of Cherry *LINK*
Jennifer Indy.USA
Pete Kekel runs Big Monk Lumber and could certainly fix you up.
Click Here for More Info!
...or do it the best way...
... which would be to start with 10/4 or 12/4 billets and then bandsaw your leg blanks out of them, carefully cutting on the rift so that you have similar grain orientation in all the legs.
Understood.  Thanks for the replies.
Re: ...or do it the best way...
Ellis, I ended up driving (way) over to a WoodCraft on the Eastside of Cleveland.
They had a perfect size piece of 8/4.
Thanks for the "cut on the rift" tip. I had forgotten that.
