Have a question? Ask Woody!
Veneering Question
Veneering Question
Veneering Question
Bartstar
I am making a serving tray for my dad. I am planning to use 1/4" plywood for the tray bottom, and wanted to finish the top side with some nicer looking veener (I have some really nice quilted Makore). I usually veener both sides of a panel for my smaller projects, but for this, I was planning to veneer just the top side. Is there any issue with veneering only one side of this plywood panel?
Thanks
Bart
Re: Veneering Question
Lee Grindinger
Yes
Lee Grindinger
But it's actually not the veneer that needs balancing, it's the glue lines. Glue lines affect the way a panel absorbs moisture and if one face takes it on more quickly than the other the panel will cup. This is why it's unimportant that the veneer on the opposing face matches but it should be there.
Also, The thinner the substrate,
Keith Newton----Little Rock, Arkansas
The more the imbalance is likely to have an effect if there is any MC change.
If you are making a family heirloom, and want it to last without self-destructing on your dad's shelf, it would be a safer bet to just do both sides the same.
Joseph Mulherin, Sr
Bart, try looking at this website for some good ideas for breakfast/laptop trays:
www.breakfasttray.com/laptop.htm
Tony - Memphis
Well, I may be lucky but I have veneered a handful of small panels using plywood as a substrate with veneer on one side only. I haven't had any issues with them. I use commonly available plywood and UniBond glue. Typically, I finish with a wipe on (Antique Oil, General Finishes, Gel Poly, etc.). I have used birdseye maple, mahogany crotch, etc. I have also done many panels with MDF as a substrate on one side only with no issues. I do finish both sides most of the time.
Tony
