Switch on Dremel Tool Question
I have a variable speed Dremel. The switch slides form one to five. Its gotten glitchy. I tried blowing it out. No help. Has anyone tried replacing the switch? Worth it? where did you get the switch? Should I just buy another dremel?
Re: Switch on Dremel Tool Question
Steven Antonucci
If it's a loss of power at a specific setting
Steven Antonucci
try changing the brushes on the motor. Mine will cut out on 4 or 5 when they get worn. They sell them at the big box stores right next to the cutters...
Steve
steve mackay
I go through the hand-helds like Klenex. Pick 'em up at pawn shops for twenty bucks. I've opened them to eyeball those switches. Its kind'a a copper band the switch rides on. Pretty thin copper. Over time it just waers through. Found out ordering that part would cost about ten bucks with shipping and such. I figure the brushes and / or bearings are going to throw in the towel before I get that ten bucks back out of it.
I gave up changing brushes too. Like to many products these days they are built to be disposable.
You could try a cleaner...
John in NM
Way back when I was in high school and worked in a stereo repair shop, we used to clean scratchy volume control pots with a "tv tuner cleaner" product from Radio Shack, followed by Tri-flow for lube. If you have any cleaners like that around, you could try a spritz and see if it helps. I never had much luck repairing Dremel's, and after consuming three I bought a Foredom.
Barry I'm about to find out. I have 4 dremels. I pick them up at Flea mkts and pawn shops. My oldest that I bought new and one of the recent purchases are both starting to make noise. I thought I would look into new bearings and brushes to keep them running. I'll let you know what I find out.
