O.T.:,,,free GFCI cord
fixitgood
Disclaimer:I am not a licensed electrician. NEMA 1
All NEMA 1 devices are two-wire non-grounding devices (hot-neutral) rated for
125 V maximum. NEMA 1-15P plugs have two parallel flat blades, 1⁄4 inches (6.35
mm) wide, 0.06 inches (1.524 mm) thick, 5/8�23/32 inches (15.875�18.256 mm)
long, and spaced 1⁄2 inches (12.7 mm) apart, and are commonly found on household
lamps and consumer electronics such as clocks and radios. ... Plugs may be and
receptacles must be (since 1948) polarized to preserve the identity of the
neutral conductor;
==> the blade connected to NEUTRAL (ground,low side) will be WIDER (5/16
in/7.938 mm) than the other,<===
and polarized sockets will only accept a polarized plug in the correct
orientation.
http://en.wikipedia.org/wiki/NEMA_connector
The NEUTRAL (ground side) will be silver on a receptacle. -- 'High' "hot'
side will be brass or a darker color. - - -On lamp cord 'zip cord' the NEUTRAL
will have ridges on that side and be connected to the wide blade. - - - The
'HOT'(or high) side wire will be smooth and connected to the narrow blade.
'hot side'=black wire=brass screws=narrow blade or prong=smooth side
on lamp cord.
neutral side=white wire=silver screws=wide blade or prong=ridged side
on lamp cord.
http://www.hometips.com/how-it-works/wiring-electrical-outlets.html
O.K. When your hair dryer 'dies' and it has a ground fault circuit
interrupter-
the fat plug with buttons-cut the cord off as close to the dryer as
possible,save it,
install a polarized female cord receptacle-OBSERVING POLARITY-and you have an
extension cord that is GFCI protected and be a little safer.
Which reminds me, it's time to throw some away.
