O.T.,,steel/iron corrosion preventative tip
Chris Hays,Cincinnati,'fixitgood'
I save the moisture absorbing silica gel packets that come with shoes,some
foods,
and other products.Put these in a sealed container of screwdriver bits,drill
bits or
hardware and tools to prevent rust......Chris Hays
Re: O.T.,,steel/iron corrosion preventative tip
Good Tip
You can "recharge' those packets by baking them in your over at about 180� for an hour or so to drive out the accumulated water vapor.
You'll get even better performance if you use Zerust along with the Si gel-pacs. Zerust emits a vapor in a closed space like a drawer or tool box to prevent the oxidation reaction. I use their drawer liner material for my carving chisels and their small blocks in each of my tool boxes.
Re: Good Tip
Chris Hays
Thanks Mark.I did not know that....."a penny saved is a penny earned"Ben Franklin-I
think.
