THE WOODRAT IS BACK!
OT - Water Heater Question
Warren White
This is a problem that has come up before for me, but I don't have an answer. Perhaps some here might have experience.
I have a natural gas water heater in my garage. When the ambient temperature in the garage climbs (it was 85 yesterday), it confuses the thermostat on the water heater and we wake up to warm, not hot water. This happens often in the summer; never in the winter.
Any thoughts would be most appreciated.
Warren
Re: OT - Water Heater Question
del schisler
I did a google search The thermostat shouldn't change It may be bad you can Probly change it It should sence the temp of the water not the outside temp.
The Dip Tube
"The dip what?" you might say. In every water heater, there is a plastic tube parked in the cold port that brings cold water to the bottom of the tank to be heated -- and preventing it from mixing with already-heated water in the top of the tank.
If that falls into the tank or splits or breaks, then cold mixes with hot and suddenly your water heater doesn't work nearly as well as before.
There's a ton of Americans out there who know all about this because of a debacle a few years ago. The company that makes most of the dip tubes in this country changed its formula for the plastic. The new plastic was prone to disintegrate in certain conditions. The operative time period was August 1993 to March 1996. Aside from gradually or suddenly having much less hot water, the telltale was finding bits of plastic clogging faucet aerators.
There was a scandal, class-action suit, and settlement. But the terms of that expired several years ago, so if you find you have the problem, all you can do is try to deal with it. Even after replacing the dip tube and flushing the tank, you might still find plastic bits for awhile. But at least the water will again be hot.
Debacles aside, you should also be aware that even good plastic will eventually become brittle with age and hot water. We've found dip tubes in old water heaters that were split and broken. It's entirely possible for a water heater to outlive its dip tube. Simply replacing this inexpensive part can restore your tank's function to new and save you the cost of a new heater. So think about that before you run out and buy a new one if you experience this problem.
Bill Turpin in WNC mountains
What is the thermostat set for? Too low would contribute to your problem. Set it a little higher and mix in more cold water.
The thermostat is charged with a small amt of liguid that expands with rise in temperature. The fluid can ONLY leak out causing the gas valve to not close when hot. This is not your problem. Have you cleaned the scale out of the bottom for faster recovery and a larger quantity of already heated water? The gas valve and thermostat are usually one piece. Not a cheap part, over a hundred $.
FredD
Have a Plumber check out the Thermocouple ,this is where most temp problems originate from.
FredD
The thermocouple is part of the gas safety system, not the thermostat system. Gas water heater controls have a probe that screws into the tank. It tells the valve to open and close.
The thermocouple generates 30 millivolts when a pilot flame is present. This small current keeps the gas flowing. Shuts off the gas to keep from having an accumulation of un-burned gas.
FredD
When your right , Bill your right.
I don't know where that reply came from , except to say I have seen so many thermocouples fail that it popped up in the outbox in what passes for a brain for me.
FredD
Warren White
I have appreciated all of the replies my question generated. I tend to think it has something to do with the thermostat but hesitate changing it unless someone else has experienced the same symptom.
No, I haven't cleaned out the sediment in the bottom of the tank. It is one of those things that I never have done, even though logically it makes sense.
This really is an intermittent problem that is directly connected to the temperature in the garage. When the water heater heats, it does a very good job. Lots of hot water.
Thanks again to all who responded.
Take care!
Warren
