Re: Refinishing cherry veneer
Chuck, can you be a little more precise as to what "most" is in your view?
Cherry's tendency to splotch due to the fruitwood compression issue makes it hard to tell you where to go with this without the piece in front of me. I suggest the your wet the entire surface with either de-nat alcohol or naptha to see if there is still some of the film finish present (it will show up as lighter patches where the liquid doesn't soak in a bit. Take your scraper (wise choice) back to any spots revealed.
Once you are confident that all film finish is removed, you can choose to color with a stain (oil or NGR only) or, if you've got serious color differences, a 2-part bleach application, followed by stain.
Once coloring is done and even, make a thin application of fresh dewaxed shellac to seal the colorant (oil or otherwise) to prevent its leaching into the waterborne. Since you will be using Target (great stuff) know that they strongly recommend nothing older than 3 months including SealCoat when sealing with shellac. The shellac tie coat must be thin (no more the 2 light coats) and freshly mixed/made to avoid cold checking under the waterborne.
Lastly, give the piece at least 3 days to fully evaporate the sealer solvents before applying the Target. This prevents lingering solvents from messing with the Target chemistry.
Hope this helps
