Have a question? Ask Woody!
Back to the Bandsaw (Tuning Project)
Ken Bellock (Houston, TX)
Had a few hours here and there the last couple nights, and found the 1 3/16" socket that I needed to get the lower axle shaft bolt off with. I didn't take any pictures during that phase, but that bolt was so over-torqued on there that I couldn't get the thing loose with a 2' breaker connected to the socket. I hooked up the impact wrench, and fortuneatly that got if off quick and easy. Once the wheel was slid out, I found out that a previous owner had already shimmed the axle, with a couple shims, so I pulled them out, and put it all back together. ... After that, I believe I put took the wheel off and put it back on at least 10 times... but the way it worked out was the previous owner had just overshot it with their shims, I took half of them out, and then it was dead on co-planar. My lesson learned which would have saved me pulling the wheel off at least 7 times, was that you should check the co-planarity of the wheels with the blade on and under tension.
So, wheels coplanar, blade tracking dead center on both the top and bottom wheel, I am happy and ready to move on. Before putting the table back on, I wanted to do some adjustments to the lower bearings, so I set them all properly using the dollar bill trick.
Then I put the table back on, and used the square to make sure the table was square to the blade.
And tweaked the upper guide bearings.
After setting the upper guide bearings, I slide the guides up and down, and noticed that the bearing guides needed to be adjusted slightly when used at different hights. There is a bit of tweaking that can be done with the mechanism that slides the guides up and down, but it's close enough that I'll save that for another day. For now, I'll just adjust them when I set them to a different height, it's pretty quick with all the adjustment wrenches attached to the side of the saw with magnets.
I then broke out the boeshield, rags, and scotch brite pads, and gave the top a good cleaning. Ugh, I have to say one of my pet peaves is cup rings on cast iron... but more dissapointing than the number of cup rings was the feeling I got when I ran over the slot the blade fits through... The table is warped!
I tried pulling out the bolts to the trunion and shimming them, but that was no good, the way it's designed, with the shims it just slides further down the slot. At least the low side is on the outside of the table, and if the work piece is referenced on the left side of the table till it gets to the blade, the right side of the table comes up to meet it at the blade...
Any ideas on how to fix this one?
BTW, she cuts so sweeet!
Re: Back to the Bandsaw (Tuning Project)
Re: Table
Looks like you're doing a nice job with your restoration. Unfortunately, cast iron being the imp that it is, the cures for a warped table ain't easy.
1. Get a new table (if they're available)
2. Have it reground in a mech shop. May have to have the miter slot redone as well.
3. You can try to clamp the halves flush with a pipe clamp, then drill a 3/8" hole into the slot from the end to use a registration pin. You can also drill and tap the hole and use a 3/8" bolt instead of a pin. The smooth pin is nothing more than a 3/8" bolt with the threads cut off. The issue here is that while you may get the table edge to meet, that warp may manifest itself somewhere else on the table to take it out of dead-nuts flat.
Good luch
Dick Coers
On mine, the fence mounting angle iron bolts up on that end of the table and should pull it flat when all is tightened up. Do you have something similar?
Marv
Hi Ken,
Is it possible with the use of a C-clamp to force the two surfaces in line with each other? If you can, you might trying to drill and tap as large a thread as the thickness of the casting will allow right into that blade slot. Depending on how much it takes to force the two top surfaces into line will determine if the threaded bolt will hold the two surfaces in place. You'll have to remove the bolt each time you need to change the blade.
The only other thing I can think of at the moment is to take the table to a machine shop that can surface grind or mill it.
Marv
Re: Back to the Bandsaw (Tuning Project) *LINK*
David Hay Denver
My bandsaw (a Rikon 14") has a table slot similar to yours. This must be a common problem, because on my saw there is a bolt that sits in a counter-bore from top to bottom. You can see the bolt at the very edge of the table slot in this picture:
http://media.photobucket.com/image/rikon%2014%252522%20bandsaw/Chipncut/My%20Rikon%20bandsaw/DSCF8939.jpg
BINGO!
Still had the fence sitting off to the side. Wanted everything perfect before I mounted it back so I could set it for the blade drift at the same time. That brings the edge's flat, but running a straight edge across the table shows me it is still not "dead nuts" flat. There is the slightest bit of a dip at the slot for the blade. I didn't measure it exactly, but it is small. Good enough to start enjoying the bandsaw!
Thanks everyone for your tips and input!
