Building Light Fixtures ...
Joe Burke
I have to build a ceiling light fixture for a kitchen, and I'm trying to gather as much information as I can. I've Googled a bunch of topics, but information seems scarce. I'm probably not Googling the right terms.
The old fixture was a 4 foot, 4 bulb fluorescent strip covered by a wooden box and crown molding with plastic egg crate as a diffuser. It was attached directly to an old popcorn ceiling and the entire operation didn't do the ceiling any favors. We're going to simply replace the old fixture with one the same size. That should cover the sins of the ceiling as we've ruled out any ceiling repair. The damage is too extensive and popcorn is a bear to deal with.
Any technical info with regard to heat dissipation, heat shielding, materials for diffusion and high lumen output (if that means we need to get a lot of light out of the fixture) would be appreciated.
I'm not looking for a lesson typed out on the boards here (although I'll take anything) as much as being pointed toward the right source of information, whether it be books, magazine articles or links.
Thanks
Re: Building Light Fixtures ...
Bill Tindall
I have built several ceiling "fixtures" and they all have been functionally successful, so I don't think you need to over think the task. If you supply the amount of ventilation that commercial fixtures have, yours will be adequately ventilated.
It's getting light out that is a challenge. If you need light then you need to arrange for as much diffuser area as possible, the ultimate being to go buy a "cloud" fixture which is all diffuser( I have several and like them). It is not an easy task designing wooden framing such that the wood is minimal, with the diffuser occupying most of the area. For a box-like fixture it seems to be important to have a means for light to escape the edges of the fixture as well as the surface parallel to the wall. If you put the lamps in a "box" with solid sides and a diffuser you may be disappointed with the light out put.
The picture shows an example of a corner lamp I made for the kitchen. It was a challenge for me to accomplish the wood framing, but it does put out the light. It is mounted off the wall a bit to allow light to escape the back and illuminate the wall behind it.
Clint Searl
Clint Searl
For easy and effective, the fixture pictured can be put together. The baffle is suspended below an outdoor fixture from components attached directly to the ceiling box. The fixture will take up to four light sockets, and with CFL's and open air flow, no heat shield is necessary.
Clint
I made a bunch of them over the years. Basically enclosed fluorescent fixtures in a box with a diffuser for a cover. Have been using two of them with 8' fixtures for over twenty years.
On most of them, the box was just sealed at the top so the light would not leak out around the box. (Light leaks look like crap unless they are the diffused kind.)
On one or two I made a double top with holes positioned to let air pass through but to contain the light.
I also made a bunch of the mirror frames with bulbs surrounding them. The problem with them is that they had ten or more bulbs and the bulbs cost $3 or $4 each. If one bulb went out you had to change them all. Even if you saved spares out of the original batch, by the time they burned out, they were a different color. And every time I went back to buy another one, they store had changed the brand or style.
In the days of incandescent bulbs this was a big deal. They put out a lot of heat and did not last long. (Had one client that insisted on 25 bulbs around a mirror. Insisted they had to be 60 watt bulbs. Turns out 1500 watts of hot light bulbs will raise the temperature of the bathroom pretty quickly. And, Nobody wants to see themselves quite that well first thing in the morning.)
Incandescent bulbs are going by the way side, being replaced by CFLs. Now CFLs are going the way of the buffalo being replaced with LEDs. They are ridiculously expensive right now and the color spectrum is not great, but they are getting cheaper and better and last a very long time and use less power.
Joe Burke
Thanks guys. All good info.
Bill ... did you buy that diffuser with that curve or bend it yourself? Looks pretty neat.
I imagine I'm going back with the fluorescent light, so heat won't really be an issue this time. I imagine a lot of this is common sense, but I'd love to find a good reference on the subject. Don't know if it exist or not.
I guess the real question now is about diffuser material. Some white form of plastic ... the type used in the cloud lights referenced ... would be ideal, I'd say. Any input along these lines? I still say we need all the light we can get, so if something else would work I'm all ears.
In a different situation some stained glass work would be nice, but I wonder how much light you lose with the milky glass. The budget won't stand it this time around either. This is a remodel for eventual sale.
Joe, I bought diffusers at Lowe's. They were abut 2' x 4' and meant to go into dropped grid ceilings. Check the size, they may be slightly undersized. They were brittle. Very easy to break, so be careful handling them. I never tried to bend them, but I doubt you can bend them on a close radius. You might be able to heat and bend them,but I still have my doubts. The were cheap, about $5 if I remember, but that was about ten years ago. They had several patterns and also the open grid type.
Joseph Mulherin, Sr
Joe, go to HD or Lowes and look at their drop-in ceiling panels. I did this for a guy for his panels replace3ments and they turned out very nice....and he just loves them. Cut them to size and install in your fixture.
