Fluorescent Light Strobing Effect
charlie belden
In a thread in the Turning Forum, I brought up the idea of using a variable strobe light to "stop" a piece being turned so you could see what the grain looked like as you turned. Russ Fairflield and others were concerned about strobing lighting making a spinning tool appear to be stopped.
Now a lot of folks have use fluorescent lighting in their shops and compact fluorescent lights are replacing incandescent bulbs in task lighting at miter saws, router tables, drill presses etc. Since fluorescents are flickering 60 times per second, it's conceivable that they COULD make a spinning tool appear to be stopped. THAT could be dangerous. I've got all flourescent lighting in the shop and have never had a spinning tool appear to be stopped.
So - has ANYONE actually had a fluorescent light make a spinning tool appear to be stopped?
Re: Fluorescent Light Strobing Effect
jrecord
The old ballasts operated at 60 Hz. This gave a flicker rate of 120 per second and could cause a strobe effect. Modern electronic ballasts operate at 20,000 Hz, so the strobe effect is no longer a problem.
Bill White
Yep! I just ran out to the shop, turned on the lights, and sure enough, the lathe was standing still.
Bill
Clint Searl
Clint Searl
But if you blink real fast, it'll feel like you're standing still.
Clint
