THE WOODRAT IS BACK!
OT UPS power supply question?
Just bought a new computer and got a UPS to go with it. It is supposed to store enough power to run the computer for "up to" 120 minutes after the power fails. Also filters out spikes and surges.
Never had one before. My question is: Could I use this for general purposes after I get the computer shut down? That is, could I disconnect the computer and plug in a lamp and run the lamp a while?
Re: OT UPS power supply question?
Sure but
Don't expect long-term power from it. The "up to" caveat is just that. Usually (unless you're paying big bucks) these thing hold enough juice to let you shut down your machine and save data and documents in an orderly fashion; say about 15-20 minutes.
I have my desk phone, scanner, cable modem, router, and printer hooked into my UPS. As a matter of course, in a power failure, I shut everything down and then turn off the UPS as well. It has a power failure alarm built in, so the beeping would drive me nuts long before the juice was gone. I have an APC brand which also comes with programming. If I'm away when the lights go out, it auto-saves everything in any open programs and then shuts everything down inside of 15 minutes. This is great because before power is restored, I've often had voltage spikes and surges as they work on the lines. With stuff shut down, I'm doubly protected.
BTW, I also double filter my CPU and monitor with a second power power conditioner, so any spike has to get through two units. Hasn't happened in 15 years, although I've had a couple of UPS units fried in that time.
Re: Sure but
Neal in San Jose
There is a down side. I have the same brand, and it ALWAYS alarms when there is a power failure. When I'm asleep and the computer is turned off, it will make sure I know. but, I REALLY DON'T CARE!
I have a UPS on my computer
Forrest Addy
I have a UPS on my computer and while it gives me some time after power failure to compute it really hasn't sufficient capacity for a long session browsng the web. It will give you time ro get to a good stopping place and perform an orderly shut down but not much more. It would make sense to save the remaining capacity for a quick boot to check email, snatch up an eBay bargain, or send a message to FEMA, etc.
If you need emergency lights, those powered LED desk lamps run for about 10 hours on three AAA batteries. They put out enough light to read by or for hand tasks but not as general room light. They're cheap too about $6 - $10 each.
Re: I have a UPS on my computer
Bill Howatt
I agree. It does depend on what model UPS you have and its specs but generally doing quick calculations based on its rating will give over-optimistic times.
I was just running a router and a dsl modem on mine with a laptop running off its own battery power. It did run a while but nothing like I expected. Can't remember the exact numbers.
It does have a very loud beeper too!
Bill
Howard Norman
Barry, as others have said the manufactures of the UPS are normally overly optimistic about how long the power will last. I have a large unit on this computer but the noise of the buzzer will drive me nuts in a few minutes.
In a long power outage here I will shut everything done and then once or twice a day I will power things up to check for essential emails or such.
Re: Sure but
Walt Smith
There's a way to turn off the alarm. You need their downloadable software and their cable which has a USB plug on one end and an RJ11 or RJ45 connector on the other.
To take a shave
Al Goldstein
The only time I used my APC power supply during a power outage was to run my electric razor. This was before I had a cordless model.
Big help!
Neal in San Jose
I should have known I wasn't the only one with that issue. I poked around in my programs, found the APC program that came with the UPS and discovered that they had provided several options. I'm now set so it will not alarm between 10PM and 8AM or when the computer is not turned on. Brilliant, Thanks Walt!
xeddog
I had a large UPS for my computing equipment too. I was able to run my "normal" computer and my server with attached storage array for over 2 hours. At least when it was fairly new. Later on I could hardly get an hour out of it, and then the batteries all started giving it up. Cost of replacing the batteries was a B***H!! I don't have it anymore.
For a while, I had it in the living room and ran my tv, stereo, and other equipment through it. It ran my tv for about 4 hours during one power failure we had. That was kinda nice. Now days there doesn't seem to be anything worth watching enough to warrant a UPS.
xeddog
