need a finish for end tables
fixitgood
I am building 2 Craftsman style end tables to match a Morris chair and an
ottoman.
I will want a finish that is easy to use,not labor intensive,using as few steps
as
possible and can be purchased at Rockler,Woodcraft or a big box store.What type
AND brand name do you suggest? Thanks,Chris
Re: need a finish for end tables
Clint Searl
There's no such thing
Clint Searl
Christopher Simpson
Durable finishes such as precat and nitrocellulos are fairly labor intensive since you need an HVLP or some form of forced air spray unit combined with many coats with sanding in between. Two things come to mind that fit your needs; first lay down stain, let dry for a day. Then seal with DEFT arosol sanding sealer. Sand the sealer and coat up with DEFT arosol Satin Laquer, Finish with a wax. The second method would be to paint on a coat of shelac(button laq is preferable)try to get as even as possible. After that dries (may take a day) sand smooth then evenly apply more shelac with a smooth cloth as if you were begining a frech polish. Stop after that coat is smooth, let it cure and wax it up. Both of these processes can be done if you are stuck out in the desert and you need to finish a side table. Understand that the side table in a modern home is the most abused stick of furniture...so you may consider a piece of glass for the top. Unless you break down and go for the precat.
One simple answer
Lee Schierer McKean, PA
Use Deft Clear wood finish. It is very easy to use. Goes on well with a brush or by spraying and builds quickly. It can be touched up anytime even years later with a light sanding and another coat without problems. It doesn't impart a l;ot of color to the wood and doesn't yellow like solvent based polyurethane. My local Lowes carries it. I have pieces that are over 25 years old and they look like new finish wise. You can even apply it at below freezing temperatures.
Lee
Chris Hays
A salesman at Rockler did recommend General Finishes gel stain and topcoat. +++
He was helpful and seemed to know finishes/finishing.
Bill White
Don't know why the thought persists, but finishing cannot be fast, cheap, easy, idiot-proof, etc.
Spend weeks building and/or repairing something, then expect to squirt/slap on a coat of gack that will make the project look even better.
Finishing is an art form in itself. Study, read, learn about the products and methods that will make all the work building the project stand as a fine example of your talent.
There! I feel better now.
Quick, easy, cheap, one step.....Sure! In your dreams!
Bill
Re: Dreams
Hey Bill,
Norm puts some stain and a couple coats of Minwax poly on stuff and it all looks great, Right? I mean, Jeez, that ain't no big deal complicated art form. ;) :D
I say just pick one and learn how to use it. It doesn't have to be difficult.
