How to Edge Band this......?
Ok...hopefully this will help show what I am talking about. To my knowlege edge band tape does not flex cross-grain to follow a radius like this. So what is the conventional wisdom for edge banding the radius front edge of this form?
All suggestions appreciated!
Tom
Re: How to Edge Band this......?
Alan Young
Re: How to Edge Band this......? *LINK*
Alan Young
Hi Tom-
I'd think about this method.
Alan
Edgebanding a form
Design around it
As you suspect, edgebanding in the usual sense isn't an option. What I would do is glue thick strips of wood to the edge, mitering the joints as you go. Then flush trim them to the faces of the lamination and radius them as necessary.
Alan, must you be so graphic?
Thanks. Yeah that would work but might not be as practicle for a large form. None the less, I'll stash that as an option.
Tom
PS...thanks for digging up the graphics...or did you make them?
I think you have it Ellis
Ellis,
That is generally what I was thinking. Gonna want to get good cuts and tight joints so as to not call attention to the edge. But it seems like the logical way to go. Thanks!
Tom
Alan Young
I just "bandied about..."
Alan Young
Drew it up on Sketchup. My dimensions were 8" for the out side diameter and .5" thick for the form and the .5" thick for the resulting edbanding in both width and height.
I used Ellis method for this exact task on a set of curved doors.
It works great. My illustrated method here calls for a fair amount of hard wood waste- which I'm sure you'd find a way to elegantly use, but it does eliminate the mitered joints...
-Alan
Ah Ha . . .
'Twere it me (depending one what this item will be when finished), I'd seriously consider cutting slices of end grain of the same wood to "simulate" the lamination being a staved glue-up. In my view (YMMV) putting face grain on such an edge is tantamount to just using mica laminate.
In fact, I'd go so far as to apply the end grain veneer before putting on the final veneer. That way you can overlap the end with the face veneer and protect the edge veneer (somehwat.
Alternative would be a made-up edging treatment in a pattern of small pieces.
Steam a piece then resaw??
I've successfully steam bent air-dried and green lumber to less than a 6" radius.
Couldn't you steam bend a piece to the approximate radius and then slice off pieces? I think that pipe bending might not work in your case - the thickness of the material might be a bit much.
Re: That was my thought as well
David Hay @ Denver
Good one, Mark
Thomas S Stockton
I have used both Alan's and Ellis' technique both work very well and I choose one over the other based on looks. For doors I prefer to use solid about 3/16" thick so I can adjust the fit, otherwise veneer works well. I usually bend the core, edgeband and then apply the veneer.
One thing you mentioned earlier is you were going to use thin baltic birch for the bends, I would rethink this since BB is fairly rigid and use one of the bending plywoods. I can get luan bending ply in 1/4" and use two layers with a middle layer and outer layers of bending poplar ( 1/8") giving me 5 plies with veneer this ends up being a little shy of 3/4". This makes a nice rigid piece, if you want it stronger use just bending poplar.
Tom
