Finish for wood siding
Bruce, a MN Galoot
A buddy is putting a faux log siding on his cabin and intends to finish it natural color or some light stain. I'd heard that Thompson's water seal is not really good for this, and my own experience with my deck bears this out.
So, the question: What's a good finish for this type of siding? Brands, please.
Thanks.
Re: Finish for wood siding
Cabots
Never use Deck finish on logs *LINK*
Dustmaker Mike
I had a log home in the PNW that had a deck finish put on it before I bought it. It took me two years to get it back in shape. Check out Log Home sites and get the correct finish for them. They need bug protection then a good grade sealer to protect them.
Perma Chinck (SP) is one of the best and this is another one for supplies.
Here is one
Sikkens
John in NM
I've been using their deck finish on an ipe deck, needs a couple coats a year but it's designed to just sort of wear off rather than peel. So recoating is a matter of a couple hours if I can keep Jean and the RO sander away from it :D
My neighbor used their siding finish on his log cabin, and it seems to be holding up very well after several years. Bear in mind this is at 7000' elevation, so we get plenty of UV to kill finishes.
I buy it at a Benjamin Moore dealer in Albuquerque, home centers are unlikely to carry it.
Rick M
Look into CedarCide, dont have a link for it but I'm going to use it on my own log cabin this summer.
Re: Sikkens
Bill Howatt
I have been using Sikkens Cetol 1 and Cetol 2-3+ on my red cedar house for years. I'm very happy with it. It is a 2 coat system, first the 1 then the 2-3+.
It is a finish and it won't last forever. Sun is its enemy; where the sunny wall is shaded by the roof overhang, it is like new. Where it gets a lot of sun exposure it needs redoing more frequently. How frequent, well, that depends on the exposure and how well the surface was prepared. I can't emphasize surface preparation enough. You must break the mill glaze on new material or else it does not sink in and bond as well. You must read and follow the manufacturer's instructions, regardless of the product!
On very sunny areas I would say I recoat every 4 years or so. Not like paint, just a power-wash to get off any loose stuff and clean the surface and apply the 2-3+ coat again. If you leave it way too long then you'll find yourself down to bare wood and need to do both coats.
This year I am going to do some shady areas - these have not been done for over 10 years.
It certainly isn't a maintenance free finish but it sure beats scraping and brushing paint off siding to do a recoat.
Bill
It comes down to this...
If you decide to use a clear (or essentially clear) finish, you will need to maintain it with yearly coats, etc., as others have mentioned. When I was building large driveway gates, I think I tested every varnish, urethane, catalyzed urethane, epoxy and other available clear finish. None of them lasted more than two years in direct sunlight. Their other drawback is their failure mode, which tends to be by drying, flaking and chipping as they degrade; so once they've headed over the hill, you need to remove the vestiges of the old finish by sanding or stripping before you can apply a fresh coat.
I've found that the secret of long-lasting, low-cost, low maintenance outdoor finishes is PIGMENT. A pigmented stain, like Cabot's, as Mark suggested, will not chip or peel, and the pigment will protect the wood from the sun. When it needs to be replenished, you can roll, brush or spray it on (I prefer an airless sprayer) with little or no prep work.
My two �.
Re: It comes down to this...
FredD
Like Mark and Ellis says , pigmented stain is the way to go.
On the West coast which is famous for lots of hot Sunshine.
Olympic Stain is far and away the most used though I do not like it as well as Behrs's Emulsified Oil and Latex .
Olympic comes in three shades of any color , called Transparent , Semi Transparent and so pigmented it looks like paint.
One caution about Transparent and Semi-Transparent is, if you have fasteners like nail heads showing , they really will show after the coating is on and additional coats of the same stuff will not cover them,any better then the first coat did.
In my opinion there is no comparison in durability between the two, Behr's lasts much longer.
FredD
FredD
PS on Cabots
A note on application.
1. NEVER use a roller.
I got 6 years out of Cabot's SemTrans (oil base) by using a low pressure sprayer to apply and a 6" brush to work the surface. Hand-pump 2 gal. sprayer gave more control and, with my 6" T&G rough cedar siding, the brush was required to get proper penetration.
Christopher Simpson
At Lowes you can find Rust-oleum SPAR varnish its a marine coating. Has a bit of a natural amber tone looks great on raw wood. It has a UV protectant and stands up great to moisture. I used this product on the top rail and wheel house of a 36' danish fishing boat at the holocaust museum in Houston, Tx the boat is outside in the elements and the finish has lasted very well.
boat rail, hatch, wheel house
Christopher Simpson
Bill Howatt
I agree with you, Ellis, with perhaps one slight exception. If you get moisture behind a pigmented stain it will peel. Of course, moisture shouldn't get behind it but moisture doesn't always follow the rules. The heavier the pigment load, the more the stain behaves like paint.
Bill
Thank you all for your help
Bruce, a MN Galoot
I've forwarded your responses to my friend, and prevented him from making a huge mistake. He thanks you, as do I.
Bruce
Re: Finish for wood siding *LINK*
Jim Dillon
Bruce,
We have both a cedar-shake sided house, and a prefab or "faux" log sided cabin and garage to care for. For the cedar-sided house, I have had good luck with Behr's "improved" natural finish with silicone added. I add a mildewcide agent to it to stop mildew even more.
For out log cabin, I use one of the many finishes available from Schroeder Log Cabin Supply (link below). I like Weatherseal as it is very thick, does not drip, and seems to work well and last quite a while. Not cheap, but it holds up well and only needs one coat. Schroeder's offers a lot of different choices for exterior, interior and decks. Their service is very fast as shipment is from several parts of the US.
Jim
Schroeder Log Home Supply
How often do you recoat?
... and do you have to scuff the old finish first?
Re: How often do you recoat?
Christopher Simpson
Well, the initial restoration was in October of 2008. I have checked on the boat periodically since then with a little touch-up here and there. I was actually going to put a fresh coat on this month before the summer gets here. At that point I will wipe it down with mineral spirits and give it a good scuff sand before recoating. It will probably take less than an hour. Plus it gives me a chance to take a good look at all the joints. My Dad�s defender 90 is in the shop though so I need to find a way to get the ladder to the museum.
Re: Film-Forming Finish for Wood Siding
is called "paint" ;)
I submit one would be a candidate for classification as "mentally defective" if he/she were to varnish the entire exterior of a residence.
I had a wood boat wbw. Lovingly restored all 28' of her. The spar varnished mahogany decks gleamed, the brightwork twinkled, the laptrake hull was high gloss. Two years under the sun, and things were changing rapidly. Bid a fond farewell to the maintenance required.
I couldn't possibly imagine living in a house with that kind of up-keep.
