How to edge band a radius?
I have a project in mind that would involve bent laminations. In this case thin sheets of baltic birch with veneer outer layers. But then I would need to edge band. I have no experience with edge banding. But I assume typical iron-on edge banding does not have much cross-grain flexion...correct? So how does one edge band a cross-grain radius?
Any suggestions would be very appreciated!
Tom
Re: How to edge band a radius?
Glue on solid stock, then radius with router or shaper.
You can get flexible veneer that will bend to a bull nose, but you'll have to make the substrate shape to account for the veneer+glue thickness and then a continuous concave caul to match the outside (greater) radius. I wouldn't try with the pre-glued banding as it's too stiff. They do this with plastic all the time, but that's a whole different technology.
Probably why solid stock is used. ;)
Ed Mulligan, Cape Cod
The front doors on the little chest are bowed, made up from laminations of thick mahogany veneer with a cherry face veneer. To hide the laminations on the top and bottom edges I sliced off end grain veneers from a cherry plank and glued the slices to the door edges. As a result, the doors seem to be olid wood.
Alternatively, if your edge is thin enough or your edge tape is wide enough, just cut short pieces of tape, butted together, to go around the edge.
Thanks but not the radius I seek
Thanks for the help but I am actually looking to edge band a radius that is radiussing in an arc that is perpendicular to the grain of the edge band. I hope that makes sense.
In your example the edge band is bending around a curved edge so the banding just bends with the curve. In my case the banding would need to bend laterally to follow the curve.
Tom
Thomas S Stockton
Tom
Can you draw a quick sketch, I've done tons of stuff like this but I have a horrible time understanding certain descriptions without a drawing.
Tom
ditto
Dick Coers
If it is a fairly consistant radius, can you make an oversize form, wet down some thin solid stock, then use surgical tubing to wrap it to the form. Let it dry, and then glue to your lamination using the same tubing, maybe with a backer for better glue contact.
I'll work on something.
