OT Trailer Lights
OT Trailer Lights
OT Trailer Lights
Jerry Gibbs
Didn't want to hijack another post. If we can put a man on the moon, why can't we have trailer lights that work reliably!! Just returned from a long trip where both running lights quit half way through, but the turn, brake and flashers kept working. Looking for a fix in bad weather is no fun.
Re: OT Trailer Lights
Bill Turpin in WNC mountains
Lots of trailer light systems use the frame as ground (common), sometimes thru the ball. Add a ground wire for ALL parts of the system. This eliminates: rust, loose bolts, water, etc.
99.99% of all trailer electrical problems
Forrest Addy
Sorry to Mondaay morning quarterback but 99.99% of all trailer electrical problems can be attributed to either bad grounds or corrosion. I've made one million tralers (exact count) of different kinds of trailers and since early on I ran a bonded ground (an actual wire instead of relying on the teel structure) and sealed up or gasketed electrical devices and connections 99% of electrical problems stopped.
This means I never relied on an electrical connection for the ground through the trailer hitch. This means more installed more expensive gasketed lights and took greater care in execution but the payoff is my cutomer had no electrical problems in the pouring rain somewhere far from shelter or assistance. A partial list of the step I took includes trailer plugs and recepticles that have sealed caps to close them off when not in use. Use silicone liberally to seal around wire entrances in connectors, light housings, and attachment screws to structure. If wire nuts are the only way you know to make electrical connections then apply a blob of sealant in the nut before screwing it on the wires. Seal up everything so water can't get in.
Do a good job of this and there will be little to suggest that you applied silicone sealant to every source of water infltration. You do it leaving no unsightly blobs and smears. If you have to change a bulb later then set aside a time when you can change them all; opening each light device in turn, changing the bulb, and resealing it. Modern long-lived LED lights have to be wonderful to work with. 50,000 hours between failures.
Electrcal integrity of a trailer's lighting system is no accident. Trailers sit in the weather for years utterly neglected then get put into service at a moment's notice. The electrical system has to be made to withstand moiture and neglect.
Bill Howatt
I agree that moisture/corrosion is the major problem. I solder any wire joints. However, I've never seen a proper trailer electrical connector (but I won't say I've seen them all) that doesn't have its own ground wire to avoid using the ball as a ground conductor.
Modern cars often have the various exterior lamp connections covered in a grease material.
Bill
