Dados on Inside Corner of Legs
T Rex
I am building a game table that has legs that are 42� tall.
I need to put cross members from one leg to the leg on the opposite corner.
How would you cut the inside corners of the legs so that the cross members could be fastened to the legs?
Is there a jig that I can place on my table saw that will hold the leg at a 45-degree angle to the top of the saw?
I hope my explanation and questions are clear.
Thanks for any help,
T Rex
Re: Dados on Inside Corner of Legs
FredD
If I understand you correctly in that you want to connect a cross member or stretcher to a leg , if so, then Mortise and Tenon is pretty much standard for this.
You can cut the Tenon on the Table Saw and the Mortise with a drill and chisel.
Sounds to me like you would want to cut a few practice joints first.
FredD
I would do this
Dan Donaldson
Cut off a section of a corner the height of the cross member. This will give a flat for it to join the leg. Then use a chisel and cut a mortise, then attach the cross member. See if this picture makes any sense.
Re: I would do this
Tom Rex in TX
That is exactly what I want to do but I don't know how to cut the flat part across the inside edge of the leg.
Is there a jig for the table saw or router?
How would you do it?
Thanks,
Tom
Re: I would do this
Bob Burnet (NW FL)
Two ways, both using a jig made with a "V" trough in it. Using a Radial Arm Saw, you put the leg in the V jig to stabilize it, and cut across the top most corner of the leg.
The second is to use a table saw or router. Place the table leg in the V jig and cross cut the jig and the table leg to the desired depth. In this case you want to make sure that the jig is thick enough so you don't cut it in two!
Re: I would do this
AZ in Colorado Springs
If the table is square, then the flat will be set at 45 dgrees to the inmside egdes of the legs. If the table is rectangular, then the flat will be at a different angle, to make it face the leg in the opposite corner. Take that into account when preparing your jig.
Re: I would do this
Dan Donaldson
The simplest way is probably to do it by hand with a handsaw, a couple of chisels and possibly a handplane, especially since there are only 4 of them.
