How to polish brass?
Bill Tindall
Long story but I had to settle for some unpolished brass hinges. Would like to polish them, at least some. How to?
Bill Tindall
Re: How to polish brass?
Christopher Simpson
You should be able to soak them in lacquer thinner to remove the coating then pollish up with brasso. If you want them to stay shiny you will need to recoat with lacquer. Brasso has a small amount of wax which will protect them for a short while. so clean them with naptha or some other solvent before the lacquer coat.
Christopher Simpson
GI . . .
steve mackay
Brasso sounds hammy but after 20 years of trying all the fad brass polishing methods and products its still the hands down best method I ever used. One trick though . . . if your hinges have any releif to them and you've got a Dremel, dig through all the junk that came with it and find that cotton buffing drum. Afterwards you need to go back over the whole thing with a rag lengthwise. Brasso DOES have an abrasive quality (not much I agree, but . . .) and does leave, like, microscopic scrathches. This will even everything out. And yes (go ahead and groan) a cloth diaper is best.
Re: GI . . .
Stuart Johnson
Cigarette ashes worked if caught in an unannounced inspection. Oh, and five day deodorant pads were good for a quick spit shin.
Neither lasted for more than half an hour or so but were sufficient to get you passed.
Clint Searl
Chuck a rag wheel in your drill press and dress it with red rouge. Polish to your heart's content after washing any lacquer off. Do a final clean with acetone. The shine will last a long time.
Clint
clarification of question
Bill Tindall
I am not asking about polishing polished brass. These are unpolished hinges, like what came out of the hinge extruder. They have never been polished. They look like brass bar stock.
Re: clarification of question
Christopher Simpson
Take them to a metal guy I'm a wood guy.
Best thing I ever found for that was in the form of a wheel similar to a grinding wheel (about 1"x8" dia) but made from a compressed abrasive fiber, similar to the scotchbright abrasive pads but much more dense. This works wonders smoothing both ferrous and non-ferrous metals. Sorry, I don't remember the name. I mounted these on a bench grinder but for industrial use in the field I've seen them used on large angle grinders.
After the metal is smooth, I'd use buffing wheels to remove the scratches. For polishing to a mirror finish, hands-down best product for non-ferrous metals such as brass is Simichrome, IMH_but_experienced_O.
http://www.competitionchemicals.com/simichrome/
Just like wood.(sorta)
Virgil Johnson
Treat the brass just like sanding wood. Start with emery cloth around 150 grit (finer depending on surface finish of the brass)and work down to 400 followed by red rouge and a buffing wheel. use mineral spirits for lube while using the emery cloth.
thanks, I can do that
Bill Tindall
Re: thanks, I can do that
Dale Stansbery
Unless the hinges are rough and pitted, I'd skip the sand paper part and go straight to the rag wheel and rouge as Clint said. They should shine up to mirror finish in short order. Do be careful though as you can knock off crisp edges in a hurry.
cloth buffing wheele + jewelers rouge *LINK*
del schisler
i polish brass all the time I use the red rouge Works great here is a link to see what else as far as rouge Lot's of rouge's for different things check the link
http://www.pjtool.com/polishingcompounds.aspx
And, it would be helpful...
Grant in Iowa
To fasten them to a sacrificial board with some sacrificial screws so you don't have to buff your hands...
Also make sure you run the hinge through its range of motion and inspect the nooks and crannies and barrel of the hinge before declaring the work done.
I use a buffing wheel mounted to an arbor and chucked in my drill press. Seems to be a good height, and I can control the speed. ALWAYS buff on the side of the wheel rotating away from you in case the part catches and gets flung. On a drill press in normal rotation direction, this would be the left side of the wheel.
Also might consider putting some wax on them when they are done to prolong the shine.
You can use red rouge and a rag wheel and get a high shine on them.
FWIW,
Grant in Iowa
But NEVER, NEVER . . .
steve mackay
use toothpaste on gas mask lenses !
Marv
If you are concerned about the polished brass tarnishing, spray it with clear Lacquer.
Marv
Galen Vetterick
This would be one time when it would be nice to know a person who enjoys target shooting and reloading. I'd throw them in my brass tumbler and forget about them for a day and they would be bright and shinny with no effort on my part.
One of my other hobbies is brass restoration *LINK*
Tim Greif - West of Chicago
I used to do a lot of brass polishing. Years ago, I collected brass pressure gauges and other odd brass "stuff". I've made a number of brass lamps and have a good size collection of gauges. I found brass polishing to be a fun little hobby. I generally use buffing wheels on an old grinder that has the guards and tool rests removed.
The jewelers rouge others mentioned is good but if you're starting with a pretty rough finished piece, you really want to use brown tirpoli compound instead of the rouge. If it's a rough casting, definitely do a little pre-work with some fine sandpaper - wet or dry to get it smooth first. You'll probably find the tripoli compound will be good enough for your needs. If not, progress to the red jewelers rouge. The rouge doesn't really cut the metal, just polishes it.
Use a rattle cat of lacquer from Ace to seal the finish or it will tarnish again fairly quickly. For large valumes, I get quarts of clear lacqwuer and apply with an air brush
I just repolished a bunch of my brass doorknobs last month that were a bit tattered looking after 20 years of use in my home. Look brand new now.
I could go into the how to but you'd be better off looking at the link.
Good luck
Polishing
Re: One of my other hobbies is brass restoration
Dale Stansbery
Tim, thanks for the link, I never heard of a "rake" before for a buffing wheel, but I sure need one.
