We value your privacy.
I have the old DW733 planer. It is a good machine for me. The knives are the resharpenable type. Does anyone know if there is a minimum width for the knives? What I mean is after so many sharpenings, would the knives no longer poke out beyond their holders far enough to work?
A competent shop will not longer sharpen the knives when they become too narrow. That would be when the jams holding the knife in no longer fully engage the knife. You can make a fine chisel from an old planer knife. Takes a bit of grinding.
I was told by one sharpening shop that they recommend max of 3 sharpenings. However, that begs a couple of questions, like whether that depends on a light or heavy touch, and whether the shop has a minimum width in mind. Delta customer service told me the blades couldn't be resharpened, but mine have been done very lightly and very well for 3 times so far. However, I haven't taken a look at how well the grub screws hold the blade and how much is left.
I have the same planer. I bought a spare set of knives and i sharpen them my self. I have a grinding gig set up on a grinder. I slide the knives past the wheel and touch them very lightly to the stone. Not as pretty as a proshop would do, but it works for me. I am careful to grind all four at the same setting to keep them all the same width and weight so they are dynamically balanced. When I get a nick in a set, I interchange the knives to avoid having to grind them far enough to get rid of the nick. (Somebody is going to tell me I am crazy and this is going to explode and kill everybody in the neighborhood, but so far it is working for me. Might be one of those things that goes well right up to the point it goes really badly.)
Those knives have slots in them for the eight bolts. The slots will limit how far the knives can "stick out". There are two setting gigs that are magnetic and they determine how far to stick them out. When you can no longer slide the knives out to the gig, you're done.
I have sharpened mine at least three times probably four or five times. Obviously it depends on how much you grind off each time. I am considering buying another set of knives just because I fear they won't be available sometime in the future when I actually need them. I suppose other machines do a better job, but unless you go to a spiral cutter head, I don't see how it could be much better.
Pardon the poor picture, The grinder is stored on the shelf, behind a bunch of stuff because I don't use it often. This is a 6" Rockwell Delta grinder that is close to 40 years old. I bought the jig to go with it when I bought the grinder. As far as I know they don't sell the jig anymore. You can set the angle any way you want and the knob at the right allows you to "micro" adjust it in and out. It was sold as being for plane irons and chisels and it does a great job for that. I put a steel ruler in it and just slide the planer blade back and forth. I sneak the adjustment up as I go and take a very light cut, barely snicking the blade. For a chisel or plane iron you can clamp it in the holder and then slide the holder back and forth.
You could do this without the jig. Set the rest on your grinder to the correct angle and clamp a straight edge to it so that the knife just barely touches the wheel. You don't even have to have it perfectly parallel to the wheel. Slide the blades past until the stone stops cutting. You only need to take off enough to produce a sharp edge. If you need to take more, you could put a piece of blue painters tape on the back edge of the knife. That would be a lot.
