Have a question? Ask Woody!
microlux table saw
microlux table saw
microlux table saw
gary clarke
Has anyone had any experience with the microlux tilt arbor table saw ( minature table saw) ? I have a nice delta cabinet saw, however I have been looking at the small saw for cutting tiny( 1/2 inch thick by 3/8 long ) segments. Any experience with other small saws or advice?
Re: microlux table saw
No Experience But
I'd go with a band saw with 0-clearance throat plate or sled before I'd be doing stuff that small on a rotary blade machine.
steve mackay
I've got a lot of stuff from MicroMark. Good outfit. I had the Microlux scroll / jig saw. Bought it for the same reasons you're thinking of. I'm a scratch model maker, all wood. The saw was just to light weight. I mean WAY light weight. Anything beyond THIN basswood or balsa was to heavy. And NO sap or moisture. NONE ! The tool just wasn't as heavy or robust as the picture might imply. If I were building wood (basswood and balsa) model planes it would be fine but the minute you find yourself saying "I wonder IF it'll cut THIS", game over.
gary clarke
thanks Mark and Steve
Entirely aside from the safety issues
you'd spend a lot of time crawling around on the shop floor, trying to figure out where the saw flung them.
Have you considered a hand-powered miter box? The parts will stay still after you cut them, and you'll pay a lot less than you would for that table saw. And, for cuts that small, a good miter box will be as fast as a table saw. Quieter too.
I have no Experience with a miniature table saw. So take this with a grain of salt.
I agree with everything everyone else has said.
Experience tells me that almost any tool works better when you are not working near the limits of its capacity. Your table saw will probably cut 1" stock better, faster, and more accurately than it will 3" stock. Half or three eighths stock is pretty heavy stuff for a miniature TS. I would think 1/8" or less would be the sweet spot for that saw.
Another thought. Go to the Turning board (on the left, under Message boards) and post your question. There are people there that make segmented turnings. Some of those have hundreds or thousands of pieces and require extreme accuracy. There are books available that tell you how to set up a sled to cut segments well. Not sure, but I think most of them do them on a TS or a bandsaw.
At first glance, segmented turnings look like a great way to use up the tons of tiny scrapes we all have. I think you will find that that is not as true as it seems. Most of the people doing it start with big pieces and cut them down into tiny pieces. Much easier to get accurate cuts that way.
There is a saw that uses a blade like one of the Japanese handsaws. The blade is below the table and you slide the wood across the blade. It appears to be a very accurate tool and is amazing to watch, but the price stopped my interest in it. I think it was around $1500. Maybe somebody can give you a lead to the name and maybe a YouTube video on it.
