Fitting Ax Handle
Fitting Ax Handle
Fitting Ax Handle
Gary Smyth
This past winter I broke the handle on my favorite camp ax. No biggie, just get a new handle, fit it, add a wedge and presto�good to go.
Not so fast. First, finding a handle of the proper length at the top (ax eye) was like searching for hen�s teeth. I ended up buying a handle of the right curve and swinging length but the handle top is shorter than the ax head eye is long. I�m now carving a odd shaped wedge to �lock� the ax head to the handle shoulder as closely as possible. It will not be perfect. There will be some minor gaps, I�m guessing 1/32� at the top and who knows inside the eye of the ax. Now I like this ax. Likely no one will use it but me. The last handle lasted over forty years. So would coating the wood (from the shoulder to the top with epoxy (West System) or expanding (polyurethane) glue, or construction adhesive when doing the final set of ax, handle, wedge be of any help concerning safety? I don�t want to do this again and I certainly don�t want it popping off when I�m in back country or another 40� snowfall. I could also soak the head in oil for a couple of weeks and let the wood swell. Suggestions?
Re: Fitting Ax Handle
Tom Dunlap
After breaking too many wooden mattock, splitting maul and sledge hammer handles I started replacing them with fiberglass handles. The mattock takes care of itself since the handle and head are opposite tapers. The rest get fitted and positioned then epoxied on. Breaking handles is a thing of the past now.
I've rehung a couple of hammers/mauls and used epoxy. To date,and many whackings later, none have loosened. Every one that I had tried to fit and wedge would loosen
Before I epoxied either 'glass or wood I cleaned out the socket on the head. Using long stones in my die grinder worked well. Having the surface roughed up has to make a better surface for the epoxy to grab.
Use plumbers putty rolled into a string to block the gap at the bottom when using epoxy.
Proper length?
Bill Tindall
I can't tell if you have a very strange ax or you are inexperienced in handle fitting. I have rehandled dozens of axes, sledges, etc. The handles always require substantial shaping with a rasp to get the handle fitted into the eye. The reshaping involves removing material to enable the handle to penetrate into the eye until the penetration is just right. The head of the ax needs to seat almost to the maximum swell of the handle and it normally takes a fair amount of rasping to achieve this fit- axes, hammers or sledges.
Handle theory: When wood gains moisture and swells in a confined space (ax eye) the wood fibers are crushed and never recover. Repeated a few times and the ax handle becomes loose. Bashing in the wedge will fix the looseness. I have a double bitted ax of exceptional balance but the eye is not tapered. I have to epoxy the head on this ax to keep it on. A high quality ax will have a tapered eye and unless the ax gets very wet a properly fitted handle will stay tight for ever. Of late I have started applying epoxy to the top of the head to help (but not inside) seal out moisture. It seems to help.
Moses Yoder
Moses Yoder
As Bill said, the handle has to be fitted to the eye. I use a spoke shave instead of a rasp, but the idea is the same. I have never thought of using epoxy to glue a handle on; I wonder how difficult it would be to remove if the handle broke? A properly wedged handle has a wooden wedge going the long way in the eye of the head, and then 2 metal wedges going crossways in the eye. I have never had problems with handles loosening when they are wedged this way.
Good advice here.
I had a friend who earned his living making handles for close to fifty years. Had a small factory. He made them, his brother sold them.
It was fun watching him handle an ax for the locals that showed up to get one from the maker. He would remove the remains of the handle and hold the head down next to his hip and stare into the eye for what seemed like and eternity. Then he would take the new handle to his big horizontal belt sander and sand the end to fit from memory. They often fit on the first try.
Bill is right, you may have to remove more than you thought to get it to fit.
Like Tom, I have switched to fiberglass handles for most of my stuff. (My Friend is probably spinning in his grave as I type this.)
I have done both. Fitted wooden handles carefully and wedged them in and had good luck. On some of those I used chalk to help. Coat The inside of the eye with chalk and start the handle into the hole and sand or rasp of the part that has chalk on it. Actually, since the handle goes in through the smaller hole it will scrape and you can cut away to the size of the the scraped part.
I have epoxied on Fiberglass handles and they worked well. I had a pitch fork and the only handle I could find was way too loose, so I filled the void with BB's and poured in epoxy. A major improvement.
And I have used epoxy on wooden handles. Rasped the handle to fit, cleaned the eye, slathered the inside of the eye with epoxy, drove the handle home, sawed off the protruding handle and wedged it, poured in a little more epoxy to file any remaining voids, used putty to seal the handle to avoid leaks.
Don't worry about removing the handle is you break it, You can drill out the wood and heat the head enough to remove the epoxy without ruining the temper.
When you want to seat the head, stick the handle in the eye and with the hand dangling down, tap the end of the handle sharply with a mallet or block of wood. It looks like the head "hops" into place.
Gary Smyth
Here's what I'm looking at. The handle top was not cut down. The split was already made but I did wedge wood to fit it better to the sides. The rest is fitted decently and the handle shoulder to the ax (hatchet) is tight. It is the triangular portion of the old camp ax head (top of photo) I need to secure with a wedge. I am aware of fitting everything within the eye as tightly as possible but the eye is too long for the handle I selected for other factors. So with a wood triangular filler at the top of the eye and a wedge in the split will that be enough, or should I add glue as a filler for full contact throughout?
Epoxy/removing broken handle
Tom Dunlap
I'd fit in as much wedging as possible then fill the voids with epoxy. Using BBs is a clever idea too!
When I was in junior high I went to Camp Menogyn, a YMCA canoe camp on the edge of the Boundary Waters Canoe Area on the MN/Ontario border. They had a generator for electricity but it didn't run often. An ax had a broken handle and our guide needed to rehang the head before we left on our trip. He took a can from peaches and kinked two valleys in the lip to support the head vertically. Then he wadded up some burlap and added fuel oil to make a fire. The continuous fire was enough to get the wood burning slowly. It took some tending to keep the fire low. We did that by leaning the top of the can on the side of the ax head to act like a damper. After the wood charred/burned a little it was easy to punch it out. With a little scraping the socket was clean and ready for a new handle. Since every group had an ax all of them were the same brand and there were factory ready handles in the supply cache. The metal wedges were salvadged and reused. This was real frontiersman work! A great lesson for a teenager! I was tickled to be chosen by our guide to help with the burnout.
Drive in your wedge.
Seal the other side with tape, wax, etc.
Mix epoxy with sawdust and fill the remainder.
Sand/grind flush.
Done.
Mark's Right
I tap the handle out, coat the inside of the eye with epoxy, putt he handle back in, drive the wedge. Expect The wedge to break into several pieces. Where the slot is wider you will be able to drive more of the wedge into the slot. Fill the triangular void with something, sawdust and epoxy, tooth picks, nails, BB's a triangular sliver of wood, whatever, and epoxy, clean it up and put it to work the next day.
Flea Market Axe Heads
A. Kapocius
I've picked up a cuppla flea market axes to refurbish. Never could really find replacement handles to properly fit the eye. Mebbe someone on the Hand Tool side could offer expert advice.
Al Kapocius
a picture worth a thousand words
Bill Tindall
Ahh, too long that way. This is the first time I have ever seen a handle not fill the eye in that direction. But then, for personal reasons, you may be using a handle smaller than this ax was designed for, and that is OK. I guess if I faced this problem I would solve it as you suggested. Drive a filler in the vacancy and don't worry about it. For no good reason I cringe at the thought of adding epoxy, just a personal thing. Epoxy addition could help fill the vacancy. .
