OT - track lighting in kitchen
Andy Wright - Allen, TX
We have a vent hood in our kitchen that has a wood exterior with a galvanized steel liner. It is over our 36" Thermador range, and doesnt give off enough light (the only light is the little inset light in the blower)
I am looking at options to upgrade the lighting, and am considering installing a track light system inside the hood. There is plenty of room for a couple of halogen track lights to be installed. The lights won't be visible unless you are looking under the hood, and since the entire vent hood is lined with steel the track lights won't be where they can make contact with any combustible material.
My only concern is moisture. I know that designers install track lights in kitchens and bathrooms, but wanted to see if anyone had knew of electrical code about installing track lights over a kitchen range
Re: OT - track lighting in kitchen
My concern would be heat and grease.
Moisture might be an issue but on top of that the heat might be a problem, especially if you have 15,000 BTU burners like some stoves have. Then there is the grease and cleaning.
How about some spot lights mounted in the ceiling near the stove and aimed at the cook surface?
T.
Clint Searl
Clint Searl
Low voltage xenon track lights are bright, conveniently movable, and don't give off gobs of heat.
Clint
Forget Code
Maintenance and cleaning the bulbs and fixtures will drive you nuts; they will get coated with cooking fumes right away and degrade the light. Get grease into the sockets and you're asking for a fire.
Hood lights need to be "sealed" on the hood side, but ventilated to the outside. the law voltage halogens get quite hot.
You'll do better with a flex-track set up angled back into the "cooking area". The tracks can be suspended from the ceiling, and you can have some fun with the available fixtures.
Did my kitchen last year. I used a downdraft vent as the cooktop is in the island.
ps: DON'T forget code. a fire-trap hood is likely to void out your insurance. Not worth it. :\
Recessed Ceiling Task/Spot Lite
George Colonel's Workshop-Havertown PA
Good Evening Andy,
We just replaced our kitchen and noted the low illuimination atop the new range provided by the overhead microwave/fan/hood. We retrofitted an extra recessed hi hat fixture, and aimed it appropriately to solve the problem. Its much better now. I wish we had known not to rely on the hood/fan light in the new appliance. It really stinks. We could have planned around that shortfall and saved time and cost..
George
jared
We have track lights that I mounted on the ceiling and aimed towards the stovetop. They work good but even from nearly 5 feet away they get a little cooking residue on them.
Here is the solution I came up with. Instead of track lighting I got two xenon light strips with metal casings from Lowes ($30 each) and wired them into a switchbox which I mounted on the inside of the hood.
I looked at several designer kitchen hoods, and most of them used halogen or xenon lights with bulb covers similar to what I installed. I am happy with how the lights blend into the hood (it doesn't look like a bad home owner upgrade, and almost looks like it came that way). The additional light over the range is a huge improvement so my wife is happy
