dust collectors
dust collectors
dust collectors
Bowskin
I'm looking fo a small dust collector, found a 1 hp at grizzly,a 2 hp at harbor frieght, and 1/2 hp JET at rockler so far, not sure which it the better. only run a band saw, a table saw, and a 4x36 sander one at a time, all are priced for bout $175-$180, any suggestions? comments?
Re: dust collectors
Re: dust collectors
del schisler
get the one that move's the most air And the biggest inlet 4" or 2" Of course 4" is the best for the small collectors I have the delta with 4" and it work's very well But cost more I have the cyclone also Sure is good good luck on the one you select
Re: dust collectors
Sounds like my shop . . .
steve mackay
ShopVac & PVC do me proud and for less than a hundred bucks.
Re: dust collectors
Re: dust collectors
Glenn Madsen---in SF Bay Area
A lot of folks like their HF DCs. It's supposed to be one of the better values they offer.
I bought a bigger Delta, because that's what was available locally, and I was running more tools then than now.
What ever you buy, figure to build a drop can into the setup, so you can vac up plane shavings and lathe shavings, and not clog your filters, or overfill your DC bags too quickly. And you can better use a power planer that way, too. Much easier to dump the can than empty a mounted bag. A $40 upgrade, in my case.
Re: dust collectors
Re: dust collectors
Brian
Get yourself a good shop vac and add an Oneida Dust Deputy. It prevents the shop vac filter from getting clogged real fast.
Re: dust collectors
Re: dust collectors
Bowskin
Well for my applications, again, i am just using a tables saw and band saw, plus a 4x36 sander. no planers or lathes, don't even have them, may later on, but just the tools listed, so i will be dealing with medium-very fine dust, knowing this, what would be the best application for minimal cost? still suggest the harbor freight? i'm a little weary of HF, pop says lots of their products aren't built like Jet Delta Rigid etc., any thoughts? I'd just hate t buy some thing that break in a year with no waranty.
