OT "LadyBug" Problem
Thomas Norton
Anyone have any tips on how to handle the "ladyBug" like bugs that are ALL over the place in our house?
Thanks
Thomas Norton
Thanks
Re: OT "LadyBug" Problem
Justin Szeliga
Open the doors & windows. They're just trying to get outside. They came crawling in over the fall as it got colder, now just wanna get out.
Gary Smyth
As I understand it from our extension guy, they don't hurt anything. Just gather them and let them out. They don't eat clothes and will generally find a sunny window. Some believe them to be good luck.
How about this:
Forrest Addy
How about this: they're ladybug right? Make up a bunch of little tiny signs: "Shoes! 1/2 off!!" each with an arrow. Scatter them around pointing to the open window.
Just a thought.
They are a beneficial insect. Harmless to humans, they are predators that eat other insects such as aphids that destroy your plants. They have been bred and released by the millions because of their beneficial effect. They chose a particularly prolific variety to release. Gather them up and let them out. You might be able to lure them out by opening the doors and windows and misting/watering your plants outside. They are probably thirsty.
Asian vs domestic
Bill Howatt
If they get in your house in the winter, smell when you whack them and sometimes make you think they are biting which is more likely from the spurs on their legs than their mouth, they are the Asian variety. Other than the above, they don't have any real nasty habits and they do eat aphids and other pests but nothing eats them because of the bad smell they emit.
The domestic variety doesn't winter in the house, smelll or "bite".
Bill
Lady bug or lady beetle?
jared
You most likely have asian beetles. We have millions of them here in Iowa. Demon as mentioned below is a big help but not a cure. You need to spray it on the outside of your house in the fall. The bugs are looking for a warm place to go at that time. Spray it around the windows and foundations, any cracks etc. Demon is cheap, effective and safe. The best time to use it is in the fall but it is a help to use it several times during the year. It doesnt seem to stain paint or siding and doesnt smell at all as compared to the beetles. During the bad times of the year, in the spring when it is warming up outside, my wife, who is rather obsessed with them, vacums several times a day to get rid of them, but then the dust bag on the vacuum smells bad to. Jared
fixed it here
Thomas,
If you don't want them in the house, you need to keep them out in the fall. They can enter nearly invisible cracks, 1/16" or so. I read that when one finds a place to enter it lays down a scent trail so others can find the same spot. The trick is to discourage them from entering the house.
If you watch you may catch them in the act - it is almost always a warm sunny fall day just after it turns cooler and you will see them flying and crawling on the sunny side of the house by the 100s. The literature indicates they naturally overwinter in cracks and under ledges so they are attracted visually to horizontal lines of the house.
They are entering the house to wait out the winter and do not reproduce or damage things except for your patience.
I had a horrible problem with these a few years back. I don't have a problem anymore. I did two things:
1 - Add weatherstripping on doors, sealed up cracks around skylight seams with tape.
2 - at the first sign of the fall "swarm", I don protective clothing and respirator and douse the outside the house using a pump sprayer. I don't actually spray - it's more like squirting. I've used various products with equal success - I bought concentrate from the co-op. I spray around and on the edges of each window, door, along the eaves, near the ground, around chimney, skylights, vents - everything. I repeat this every day I see them active outside. I do this every year. I don't really try to spray the bugs themselves - I just want to make the house unattractive to them so they'll go away.
This has nearly eliminated the problem. I think I saw six on window seals where a few years ago I vacuumed them off ceilings and skylights by the hundreds.
I do not like pesticides and use them as sparingly as possible. But I really don't like little brown asian ladybugs all over the windows and dropping off the ceiling. When I spray I use a full-face industrial respirator with filters cartridges for organic vapors. This minimizes breathing the stuff and keeps any stray droplets out of the face and eyes.
I also came up with a sure-fire way to eliminate the carpenter beetle problem if anyone cares. We live in a wooden house. I went from many dozens of carpenter bees to maybe two last year.
Please about the Carpenter Bees
I have them in the hundreds. Bee Tennis is not the answer.
Boy Bugs ??
Wayne Carson
Re: Please about the Carpenter Bees
Right on the bee tennis. Good exercise but doesn't make a dent in the population.
I read that carpenter bees like to come back to the point where they hatched out to lay eggs so if you can break the cycle all you will see is the occasional bee who stumbled on your place.
I had many many carpenter bees boring holes and reusing existing holes. Most of the holes were high off the ground so instead of spending a lot of time on the ladder I modified a puimp sprayer to give me a 10' wand. (I cut the brass wand in two and soldered in a length of copper tubing, then taped it to a stick for support)
I mix up a solution of water and liquid Sevin. (It's not really liquid but powdered sevin in suspension - shake well and mix with water. When the bees are active, I insert the tip of the sprayer into each hole and pump it full of sevin. I pump until the hole is as full as it can get or the liquid comes out another hole (the bees make long connected tunnels in the wood).
Female bees in the hole usually come out and fall on the ground immediately. (Note that the aggressive bees buzzing around and dive-bombing you and other insects are males and cannot sting. The females can sting but are more docile and unlikely to.)
My theory is the sevin coats the inside of the hole so when the new bees emerge later in the year they get some of the sevin on them and don't survive. If they don't survive, they can't come back. (ha)
This has worked extremely well here. I do see bees every year but only a few instead of many.
If you choose, wait until the fall when the new bees have emerged and plug the holes with steel wool. If carpenter bees which happen to find your place don't find ready holes, perhaps they will go somewhere else. The female bees will chew through putty and caulk but won't touch steel wool!
Speaking of Sevin, a plea to anyone reading - please do NOT put powdered Sevin on any flowering plant. Honey bees will get it on their hairs just like pollen and carry it back to poison the hive. I cringe when I see green beans plants in the neighborhood dusted with white. Honeybees have enough trouble surviving in the US without being poisoned by ignorance.
Various products?
Inquiring minds want to know what kind of products to spray.
Thanks. I will think about this. They are destroying the trim on the back/north side of my house. Apparently it's in the perfect location of them. Like yours, it high off the ground and I would need a long wand. I'm a little hesitant about the Seven. I have a Arbor below that has a Carolina Jessamine and a climbing hydrangea on it. Not sure if the drippings would get on those and harm honey bees. I don't see any honey bees, but that could be because I don't pay much attention to them.
I actually bought the metal to cover the trim with aluminum. My thinking was they would not chew through that, either way, in or out. My son took the metal to a friend to have it "broken" into the right shape and that was the end of that. The friend and the metal went away.
Glenn Madsen---in SF Bay Area
Consider AZEK or similar pvc trim to replace the wood products. Not an expert, but I don't think anything eats that stuff. And you can work it with tools you already own.
You could cover any flowering plants with old sheets or something while squirting Sevin into the holes.
Re: Boy Bugs ?? Males have white faces.
Keith Newton----Little Rock, Arkansas
