Veritas - Innovation in Tools
Calling Dale Lenz
Calling Dale Lenz
Calling Dale Lenz
Ron Berlier
Greetings Dale,
If you care to share the, I would be very interested in knowing how you achieve your 'Grand Piano' finish on your flag cases. If not, that's okay.
TNX
Re: Calling Dale Lenz
Think of military boots, : " >.
DaleLenz
Will attempt to answer when I get home from work. Tried to post on WC at lunch and needed my password! Don't know if I can find my password for WC, will look when I get home.
Password
If you can't find your password, but can see a "my profile" link in the box at the top of the message index, you can go to that - there's a "forgot your password?" link there.
Dale Lenz
Dale Lenz
What I do is probably similar to what others do to achieve a high sheen finish.
Sand to 150 grit, apply a wash-coat of 1# shellac.
Apply wood filler, after drying, sand with 220 and wash-coat with 1# shellac again.
Apply one coat of lacquer, let dry several hours, 2-3 or more, overnight. Rub down with steel wool or Scotch-brite or sand with 400 grit if need be.
Apply 4-5 coat of lacquer, each coat about 10-15 min. apart. Let cure for several hours, overnight. Same as above for leveling out, removing dusty nubs, wool, Scotch-brite, sand if needed.
Apply 2-3 coat of 50% thinned lacquer and let cure for 3 days.
Using a automotive rubber sanding block sand with 400, 600 and 800 sand paper, use water and small amount of soap or painter thinner for a lubricate.
Assuming I didn�t rub through the finish while sanding, I�ll start buffing out with Maguire�s(sp?) automotive rubbing compound using a wool bonnet in my variable speed close quarter drill. Seem like I use 3 different grits, #2, 5 & 7(??), might wax after. I usually can read the light bulb information at about 5 feet away. Still can not see a fly on the ceiling in the shop, still working on that, : � >.
Started out several years ago padding shellac and got the same results. Got a spray gun and started using lacquer. Padding shellac is cheaper, by far, you use less finish, but more time consuming.
Have probably left a few step out and there maybe be an easier way(?). Heard of several folks on this board that get the same results with 3-4 coats of lacquer, wish they lived closer so that I could learn their method.
Hope this helps(?)
