New Kind of Wood
Charles Yawn
I just heard of a different kind of wood available around here. It�s left-handed grained wood. This stuff is amazing! The grain is turned 180 degrees with the grain perpendicular to the cross rays when 1/5th sawn and the early rings are after the late rings on a coplanar axis. Right now, it is only available in Unk Nown oak, Huhwhat pine and Sum Kinda Brown.
Depending on how you look at it, it is either upside down or pointing the other direction. No more feeding wood backward or upside down to cut it, and no more trying to figure which is the right end of waste left when crosscutting and which is up or down, front or back when ripping. As you can imagine, this stuff is a boon to those woodworkers who don�t know which end is up anyway.
This stuff really cuts weird on the scroll saw with the grain direction going in the opposite direction. No one has figured out how to turn left-handed grained wood on a lathe. And it is great for carving if you are left-handed and right minded.
The wood costs a little more than most; must be difficult to grow from the top down and cut the tree from the bottom up. Someone said that left-handed grained wood grows from the outside in but I don�t believe it.
The wood doesn�t seem to be bothered with any insects as most are not able to eat their way backward into the wood and others seem to be confused and just crawl around and around without being able to figure out where to start.
Haven�t tried any finishes yet; can�t find any cans that open from the bottom, and Home Depot does not carry left-handed brushes.
Here in Georgia we use left-handed grained wood for underground utility poles, houses built facing the other way and studs for second floor basements � building code requirements, you know.
Try some if you can find it. And don�t be concerned if you get a blank stare when you ask about it or try to describe it at the store; it�s just not widely know about and found everywhere just yet.
Charles
