We value your privacy.
A friend's goats kicked in the door to the feed room while she was caught in traffic. Those little buggers are stronger than you'd think!
I need to build her a new one tomorrow. It's a standard 3-0 exterior. I'd like to use pressure treated but the stuff they sell now is so wet I think it would warp all over the place. My second choice is southern yellow pine with the end grain sealed. Redwood probably isn't strong enough and isn't readily available here anyway. She doesn't have $600-$800 for a commercial solid core door.
Around here they have used Hemlock for barn siding for years. It lasts for 100 years as long as it is not in ground contact. It isn't as heavy as white oak either.
How large is the door? I generally build large doors from poplar or cedar since they are light weight. A door will last a long time, especially if painted or sprayed with wood sealer. (I replaced a couple of doors recently that were probably at least 60 years old - mostly made from oak and pine)
Oak is great and very strong if you can support it well. To keep the door from sagging, you can back it with thin ply or just brace well. You can back a lighter-weight wood with plywood also to make it much stronger. I need to build a door myself this week and I'm thinking of welding up a steel frame with a diagonal for support.
If you look around you can sometimes find some pretty dry pressure treated. (I like to buy more than I need and keep some around to dry. You can sticker and weight it to keep it straight.) But even wet pressure treated should work OK if fastened down securely. I've used a lot of soaking wet PT for floors, fastened down with screws, and can't recall one warping after installed except on a deck where baked by direct sun. I can't imagine a goat breaking a 5/4 deck board. A feisty horse, yes.
But a goat can do some serious damage. I was kicked in the face last year while trying to hobble a milk goat to train her to stand still. (She is perfectly behaved now.) Lucky I didn't lose an eye, it knocked me senseless for a time. I can't afford to lose any more sense!
Check out Habitat for Humanity's ReStore Store for a steel or solid core door for way less than $600 - probably even less than the materials to hand make one.
It's my new favorite place to shop. Prices are way more reasonable than the borg!
Locally there is a lumber yard that sells treated lumber that is dried after treatment. KDAT = Kiln dried After Treatment or ADAT for Air Dried. Much better than the wet stuff. Lighter, the ends not to warp. If you use treated, use the right fasteners.
Unlike John, I have had terrible experience with wet treated wood warping. A small percentage, but some terrible warp.
White oak would be great. Heavy, but great. Might try calling Saw mills around the area. Or try contacting Wood Mizer the makers of the band saw mills, they keep a list of people that own mills. Those guys sometimes sell wood on the side. Might find something not suitable for furniture that would work great.
Prepare an internal frame from 2 x 2 material with cross bracing, the size of the door. Apply a skin of 3/8 to 5/8 exterior siding plywood (for exampleT-11) to each side of this frame with nails and glue. The result is a light weight, strong, just fine door. I have done them up to 6' wide with good success.
Though this may not match your barn siding , I have made these type of Plywood doors for a lot of different buildings , I have three on my shop , one for my P.U. garage and they are strong as can be and not bad looking either. Two of the shop doors are four feet wide for a eight foot opening.
Using any grade of Pine or softwood lumber 3/4" thick , cut you some five inches wide and make a half lapped and cross bucked frame, the size of the door.
Working from the inside surface , glue and screw the frame to a 5/8ths T-11 panel scored four inches on center .
No fasteners showing this way on the front of the door.
Then glue and screw a 1/2" CDX or better panel to the inside and Spackle and paint.
Using the five inch width for your frame stock gives you plenty of meat for the lock installation if you have one.
A couple years ago I built a door using this method for my workshop and it is working out just fine. I filled it internally with insulation because it is an outside door. A note of caution: Be sure the 2" x 2" frame lumber is seasoned, and acclimated to the space where the door will be used to prevent it from warping after the door is finished and hung.
Forgot my camera so don't have a pic. I had to use what's available and relatively inexpensive. 2x12 Southern Yellow pine ripped to 5 1/4" and grooved for 1/2 x 1 1/2" plywood splines. The splines are nailed one side only. The pieces are screwed to the battens and cross buck only in the center and no glue was used. There are battens near the top and bottom and a cross brace on the inside of the door only. The 12" boards were the only ones without major knots. The 2x4's and 6's all had knots that went more than 3/4 through the width. I'm hoping it won't sag too much. If it does I'll reinforce it with some 1" steel strap. It got a coat of TWP 300 clear with another going on Sunday. I don't think the little buggers will be pulling another goody raid.
